Michelin LTX defender vs KO2 snow performance (1 Viewer)
HGB
In the sand
Currently have both tires but an offer stands to sell my KO2’s. The only real reason I’m hesitant is due to the road trips I have planned to Colorado that would require a decent amount of driving in snow.
I don’t plan to take more than two trips/season so I don’t want a dedicated winter tire, but Colorado roads get pretty curvy and steep so I want to be thoughtful in my consideration.
Are the defenders good enough? Are KO2’s that much better? I know they’re both M+S rated, but does that mean they’re equal?
Colorado
Soft snow, KO2s are bearable and work as well as any AT would. Ice or packed snow and they're trash. That being said, I live in Colorado full time and run KO2s. Their other benefits outweigh their drawbacks on the few icy snowy days.
TLC2013
Bay Area, CA
I have owned both, the Defenders on my LC and ran KO2s on my old suburban. On paper the KO2s with the 3 peak snowflake emblem will be the “better” snow tire. I swapped out my Defenders before driving the LC in snow. They did do great in the rain.
Reading the internets opinions on KO2s and snow will provide vastly different reviews. Some rave about its snow abilities while others say it’s awful and scary.
I would personally run something different like a dedicated snow tire or a more recently introduced all terrain that has the 3 peak snowflake emblem (falcon, Toyo, general grabber...etc).
However if it’s just going to see minimal snow use the KO2s should do just fine. Icey roads seem to be its Achilles heel. Having the 3 peak emblem on the sidewall generally avoids being forced to run chains. Plus with the LCs full time 4wd you’ll be in good shape.
Whiskerz
Georgia
Which version of the Defender ? How old are each tire ? The Defender has 2 versions and there is some overlap
HGB
In the sand
i got them last year. About 9 months ago. I have the 285/50/20 size. Does that help you? KO2 I got last month
USA
KO2, especially as new as yours, should do fine in snow driving as long as you know that you’re driving a 6000lbs high center of gravity vehicle with solid rear axle.
But Defender is probably better than KO2 in everything that has to do with on-road performance.
What size is your KO2? Same as Defender?
HGB
In the sand
My KO2’s are 275/70/17
Defender’s are 285/50/20
As you said, the defender is better on road. Because of that, I want to sell my KO2’s, but the thing holding me back is snow performance. If the defender will be as good in snow, I can make an easy decision.
USA
yeah, if you’re not off-roading, then i would just stick to Defender and sell the KO2.
HGB
In the sand
I do some sand driving and SOME off-roading... but I’m thinking about lifting the LX later and deleting AHC so I might re-do the setup with different size wheels/tires. So if I sell now then I can get a new game plan going.
Chicago
I have both and michelins are way better than KO2 in snow and ice and highway. I can drive my lx470 to 120mph if Im not watching speedo with defenders. The LC usually 80 or so with KO2. I went with DTs on my lasr set of KO2s and they last longer but slightly worse than ko2 is snow/ice.
