Metaltech Slider install, some observations.
Valencia, CA
Well I did my first true off-road mod, I installed my Metaltech Sliders. This is not a true installation thread as I was working by myself & my camera battery died during the install. Just thought I would post some observations that may be of some help to others.
First, these are one quality product. The fit & finish on these are first rate.
Removing my running boards and installing the sliders took me about 3.5 hours. I was working alone. Another pair of hands would make the install easier & safer.
Some instructions would have been nice, although the installation is pretty straight forward.
Removing the running boards requires several 13mm sockets & wrenches. 1 Standard depth & 1 deep socket. A Gear Wrench was a great help. I was at Harbor Freight today & saw, but did not buy, an adapter that would allow the use of a socket with a box or open end wrench, it may have been a big help.
Installing the sliders requires a 5/8" standard depth & deep socket, A Gear Wrench again was a great help. A 3/4" socket was also required.
The sliders are very heavy & the mounts are very precise & tight fitting. Having 2 floor jacks would be a great help, I only have 1. A couple paint cans & wood blocks worked for me.
The bolts that hold the passenger side mount at the cat could be 1/4 - 1/2 inch longer, the ones I got were hard to fit because they are a bit on the short side. Running the bolts into the threaded holes before mounting the slider would probably help.
These sliders are very stout & the build quality is second to none.
Again I would like to thank wakesetter for arranging the group buy.
Paul
I am not quite as hard on my 80 as Creeper Sleeper but following him around Browns Camp he has helped me put mine thru hell and they are by far the best mod I have done to date. Big thanks to Metal Tech.
.....Running the bolts into the threaded holes before mounting the slider would probably help.
Paul
Absolutely, I did not do this and managed to strip one of the captive nuts on the passenger side frame rail. There is not an easy repair for this so make sure you run clean out the threads BEFORE mounting your sliders.
Ross
