Metallic Clicking
Fort Collins, CO
My 97 LX450, has a metallic click that is speed based. It is definitely a metal on metal click. I only hear it above 25 mph while traveling in a straight line. Any slight turn, and the noise goes away. It is there whether accelerating or decelerating, and does not change in sound when the brakes are applied. Personally I have checked every thing I can get a wrench on. It is not a rock in the tire or brakes. Both my mechanic and myself have spent hours trying to find the source of the noise. My mechanic is the master tech at the Local Dealership, the head of our local mud chapter, and he has owned numerous 80's, so I trust him.
At first, I thought for sure the nosie was a u-joint. Found play in the rear joint and decided to replace the enitire shaft. No change. Removed Front Driveshaft and one u-joint would not move freely, so replaced front shaft. Noise still there. Knew I need to replace Birfs, had my mechanic rebuild front axle and replace all parts. Still have the click... I am totally stumped. Truck heads to Slee in a few weeks, but thought I would see if anyone else has had a similar experience. Most posts that talked about a click, problem was solved with new u-joints or birfs.
During the process, the following parts have been replaced.
-New OEM Front & Rear Driveshafts
-New OEM Birf's and inner Axle Shafts
-New OEM Front Rotors & Pads
-New OEM Spindles & Drive Flanges
-New OEM Wheel and Trunion Bearings
-All new OEM Seals and Gaskets used.
Truck has a 3" OME Lift, 285/75R16 Tires, 146k miles, No Lockers. No caster correction, will be dealt with while at Slee in a few weeks.
Does the clicking increase or decrease along with your speed?
Most likely has nothing to do with what you have going on, but I just had 4 tires balanced at Walmart (I know...I know...) and the genius tech put double layers of weights on top of each other on my spare. When I blew a rear tire wheeling, I threw the spare on and had a clicking like that. Drove me nuts trying to diagnose until I finally figured out the weights were rubbing my caliper.
Also, check your caliper bolts! I had one work its way out and the caliper would strike the wheel when braking and finally blew out one of my rims.
Probably just throwing darts at the board guessing, but it looks like you've tackled the obvious ones.
Thanks for the reply FZJ80 in KC. The noise does increase and decrease relative to speed.
Caliper bolts and wheel weights were the first 2 things I checked, and I made sure my mechanic double and triple checked them.
Is it the cards in the spokes?
I also have a "click" sound. I notice it on tar and gravel roads, not so much on smooth asphalt roads. The click sounds just like a rock or nail in the tire. I hear it from about 20-45mph, then the wind noise washes it out. I swear it is coming from the left rear tire.
I've serviced both axles including bearings. All new rotors, pads and rebuilt calipers. New ujoints in rear shaft, new Tatton DC front shaft. New shocks and springs. New swaybar bushes front and rear. The only thing I haven't really touched is the ebrakes.
All of this was done as PM, not chasing the click. It has made this noise since I bought it. I'm on my third set of tires. It even did it with the Michelins. It's weird. I never ride in the passenger seat, so I don't know if the right side does it too. I'll be watching this to see what you find.
Soon after i bought my LC I had the local mechanic service the e-brake (po said it wasn't working properly) - basically after he did that there was a metallic clanging sound that increased and decreased with speed - coming from the rear left wheel - he said i need to replace a certain part of the e-brake back there (can't remember)....doing a brake overhaul this weekend so will try and see whats up......
He managed to get it so it doesn't 'clang' as much but it's there.....sometimes.....
UPDATE:
I took the LX into Slee a few weeks back to get the OME caster bushings installed. I was not able to duplicate the clicking noise while I was with the Slee tech, which was a bummer. I did hear it a few times on the trip down from Ft. Collins, but it was not constant like it had been before replacing the birfs.
On a side note, I had always noticed that the whole truck leaned to the left, while at Slee they realized the PO had installed the front springs on the wrong sides so I had them flipped. I also had the front sway bar bushings, and the front frame side control arm bushings replaced.
The good news, I have not heard the clicking noise since!!! Not sure if it was because of the angles on the front u-joints, or something completely different. I would say it drives like a brand new truck with the new castor bushings and drive shafts. Replacing the rear driveshaft also completely eliminated the clunk I had when coming to a stop or letting off the accelerator.
The clicking noise I had has not returned after my trip to Slee last fall. I really never found the smoking gun. Since last fall, I have also swapped out the wheels and tires. The new BFG's ride much better, and are way quieter, so if the click was there I would definitely hear it.
Unfortunately I now have another noise that has come up. It happens at about the same speed, so maybe they are related. I now have a loud high pitched squeal coming from the front end when moving above 25mph.
UPDATE:
I took the LX into Slee a few weeks back to get the OME caster bushings installed. I was not able to duplicate the clicking noise while I was with the Slee tech, which was a bummer. [snip]
I like stories with endings, even if the end is, "We didn't find the cause, but it stopped."
I hope thebigtexan gets his sorted out.
