Melted Hose Identification
Atlanta
Hey
Need some help with the part name and number of the hose pictured below.
I have searched the digital fsm and can’t figure out which hose is correct. Also not knowing the name of the hose makes it difficult to do a helpful mud search.
Thanks in advance.
This hose runs below the radiator in the gapping between the radiator and battery tray.
I believe it is part of the cooling system for the transmission? Maybe?
The first image is form above and the second image is closer in for a location bearing.
I think that is the power steering high pressure hose.
Pressure Hose
44411-60430
But like Jonheld says...does it terminate at the pump/steering box?
Looks like one of the two power steering high pressure lines, also looks like only the plastic spiral wrap may have melted.
I don't know if the pressure line itself has a higher melting point, but it may. You may find that removing the melted spiral wrap shows an undamaged pressure line and if it's not leaking and the power steering works fine you may not want to change it? All depends on personal preference of course but a good option if you are any version of cheap/lazy/frugal/whatever...
Thanks for the reference. It does appear to terminate at the steering box. I do not have any power steering fluid leak and all levels read normal.
Unsure how the covering melted, my only guess is some sort of corrosive fluid. The cruiser has been mostly idle for the last couple years and I just noticed this while tinkering around.
Thanks for the help.
I noticed that on my '97 this same power steering hose not only has the plastic spiral wrap but also a layer of foam between the plastic spiral and the power steering hose itself. Looks like all that's melted on yours may be that foam layer. Did you use any intense cleaners in that area or spill something on it like battery acid or power steering/tranny fluid or something similar that melted the foam chemically?
