Build meet tucson
Time to get caught up. I am one adjuster anchor on the left front away from having that all complete, but I jacked my back and it's not cooperating so I decided to do a few easier projects. I started with trying to find a fan belt. After a battle breaking bolts off to get the bib pulled, I got the blade and old belt off and found our casper store had an old belt that appeared perfect. I could've checked but il had pulled the thermostat housing and water pump off by the time our gm brought me the belt.
The thermostat housing had wrong bolts threaded through it, but I was able to retap it and put 8mm studs in. It also had no thermostat, but enough dried crystallized antifreeze to take up the space.
The water pump was seized solid with rust and I thought it was a goner, but for grins, I dropped it in some evaporust. For the full story, look in the water pump thread, but here are before and after shots
I need to finish getting the pump apart and order a rebuild kit, in the meantime I ordered a 5 gallon bucket of evaporust because this stuff is the $÷4/ and ill work on the radiator cradle next.
Meantime, with the bib off, it was a good time to replace the sad flat motor mounts and ill clean up the front of the motor. I guess since im onto the motor, it's also time to put some oil down the cylinders and try to bar it over....
More to come later....
So...continuing the battle, I tried to finish getting the water pump apart and this happened :(
I did get the passenger fender off and got all the plugs pulled and dumped marvel mystery oil down all the cylinders. Tomorrow ill try barring the motor over...im not hopeful :(
In the meantime, I went ti replace an autozone fix on one of the coil wires and the stud snapped off. :(
I did get one grommet in the firewall. Tomorrow, ill pull the cables off the carb abd get that grommet replaced and swap the rear motor mounts. Hopefully be motivated to work on the one last brake shoe anchor and get that behind me.
Ige have you soaked the pistons in 1/2 diesel and 1/2 ATF? I filled the cylinders in my ‘63 down the spark plug holes and let it soak for several months. Worked like a charm. It’s cheaper than Marvel Mystery.
You can also make a tool and stick it down the distributor hole to spin the oil pump w/ a drill and circulate some oil around the engine as well. I’ll get you a pic this week.
never used diesel atf for that, just for cleaning parts. put marvel in saturday afternoon. engine bars super smooth and rings are in good condition judging by the amount of marvel that shot out all the cylinders when i spun the engine. ;)
i have a long screwdriver whose handle didnt appreciate me using it for an impact and shattered. nice little shaft was left under the handle so i've used that to put in the drill for priming. long way away from that though.
still need to get a bunch of wire harness repair done. it's missing a lot of the connectors and nothing is hooked up. battery cable has been cut....yeah.
