May be a stupid question...
Georgia
Okay guys this may be a stupid question but I have to ask it. I have a 97 fzj80 that came from the factory unlocked. I installed a rear aussie and am keeping it AWD with the VC. My question is are my only options for a front locker going to be an e-locker axle swap (I plan on the e-locker in the future) or arb air lockers?
I know I cannot add another Aussie in the front with it AWD right? It would be awesome if I could. Has anyone tried this on an AWD?
I was thinking is there any sort of limited slip that I can install up front? I will never really need the front locker but I just want some extra piece of mind that I wont get stuck. So to nutshell my question: Can I put an Aussie locker or some sort of LSD in my front differential or are my only options an e-locker swap or air lockers? Keep in mind that I am dead set on keeping my truck AWD (I have CDL button) with my VC installed. Thanks guys!
If doing a locker and keeping AWD it does need to be selectable.
X2 ^^^
Add a winch instead for piece of mind if you don't already have (can't see sig on mobile)
A limited slip could work, but depending on how "tight" it is, you'll most likely feel it when you're driving. I'd imagine it'd feel a lot like torque steer in a front wheel drive car with some decent power every time you turn a corner. A lunchbox locker (Aussie, LockRight, etc.) in the front would make driving your AWD 80 a miserable experience and would probably be unpredictable (possibly unafe?) on the street. The "right" way to do it is to run a selectable locker up front. I know it's a lot more money that way, but where this could be a safety concern I'd say it's worth it.
Or leave the front diff open to preserve the street manners and buy a winch like recommended above.
What kind of offroading are you planning on doing? What's your primary usage of the truck? When I bought mine, I looked for the creamiest of creampuffs to start a "moderate" build with and it was unlocked. Over the last two or so years, I've added the armor at all sides and a set of MTs with a small lift. I've only desired a locker maybe twice in the time I've been offroad. I'm not doing the hard trails with this truck but each piece of armor has been used. Point being - these vehicles are pretty capable without lockers.
As far as the rear locker, I've heard their more pronounced on other vehicles but fairly subtle on the 80. They're a little tricker to drive in turns and during the winter months - it may be worth researching to get an opinion yourself.
Best of luck man!
Best of luck man!
I have bumpers, sliders, and skids already. I also have the rear Aussie like I said. My truck will be used on some hard trails but no rock climbing. Its also my DD so I wouldn't want to risk safety with a front locker that was not selectable. So i'm thinking I am going to stick with the front e-locker swap unless there is anyone who has done a front LSD on an AWD truck with good safe results.
It would no longer awd-it would be budget 2wd part time without the benefit of the t/c being disconnected with a part time kit-$$. The d/s and axles/diff would always be turning-freewheeling under no load OR bind because they are locked out at the hubs. Not much different than running a part time (like a 40) with no lockouts (but with drive flanges as many of those came equipped factory). This way it would just be spun from the other end.
