max tire size
miami, fl
what is the max tire size i can run on a 98 tacoma with an OME 1.5" lift?
With trimming, you could do 255/85 or maybe 285's. Without trimming, I'd guess 275's. Hard to say, because I've seen two trucks with the same lifts and tires, and one would rub while the other would be perfectly fine. :confused:
that guy with expeditions west had a write up on his site how to put 33's on it. He hammered the pinch welds. 265/75 fit on my stock tacoma with very little rub so I would go bigger than that. I think that works out to right under 32 inch tire BFG AT
Hi guys. I'm new here and I just got my 6th Toyota 4Runner, a 1997 with V6, 5 speed, and factory locker. My question concerns using different wheels on my rig. I current have the 16" wheels it came with, and therefore the 16" rotors and drums. I kept the 15" alloy wheels and 31" BFG tires from my previous '94 4Runner and would like to use them on the '97. My question is, if I swap out the 16" rotors and drums (which need replacing anyway) and install 15" units to accommodate the 31-10.5-15 set I have, can I still use the 16" 265 tires and wheel on the 15" rotors and drums?
Inquiring minds want to know...
Yes, but it would be a stupid move IMO to swap smaller brakes onto a 3rd gen 4runner. Sell the rims/tires and buy some in a 16 or 17. You probably should start a new thread with this question.
As to the OP, I run 265/70/17's without lift on my 96 and have no rubbing whatsoever. They are a full inch taller than the stock 265/70/16's. I think you could probably go about an inch taller, so that'd be like a 285 on a 16 or I'm not sure what they offer in a 17 that is comparable. Or a 235/85/16 if you like em narrow.
Well, Lord knows I don't want to be stupid :) While I have seen wilder mods, I can see your point, though it would be dissapointing to get rid of those wheels whose looks I like and and has BFGS is great shape. I will consider that, I did see some wheels I liked at Tire Rack at a good price. If I stick with what I have and get additional wheels, I wouldn't get larger than 16; I'd use them to put on mud or swamper tires.
BTW, I did start another thread on this question. Thanks for the feedback.
Stick with the 265/75/16, cause they will work with less rubbing. I had a 2.5-3 inch lift on mine, and they worked just fine. Just recently switched to a 255/85 and have some definite rubbing. Nothing you can't ignore though.
I agree--do NOT get smaller brakes just to put on 15" wheels. People already have a problem with the bigger rotors warping. 15's would even be worse.
BTW, 265/70/17 = 265/75/16. 285's are 33" tires, which will most definitely rub without major bending and cutting.
265/75/16 w/ bfg AT's I think that they say it's 32". I think it all depends on the companys. I don't rub that often.
I have the 265/70/17's and 265/75/16's on the factory wheels. The 17's are definately taller, but slightly narrower. The 16's are also a LT tire and the 17's are a Pmetric. May just be brand differences. The 17's are Bridgestones and the 16's are Yokahamas which generally run small.
I run LT 235/85R16 E load rating..it's a 10 ply 32 inch truck tire... tall and narrow like Jetboy said.. I like the Michelin M/S as they balance up nice, run quiet & smooth and run darn near forever. They don't rub either!
96 4runner though just in case clearance is different than a taco
Yeah, I'm guessing it's just the difference between manuf. Because just going by the measurements, they should be the same width (265mm). And the 265/75/16's are actually 1.1mm taller than 265/70/17's. But actual measurements vary and so we just say that they are the same size.
