Master Cylinder
Hi all, was just checking my master cylinder and noticed the small reservoir was dry and the larger was full. Shouldn’t they both have fluid? If so, any reason why the smaller would be dry. The FJ40 has been sitting for the past two months.
Okay, maybe it’s okay. Fluid is below the rubber insert - can’t say I have ever seen that setup before.
I have a similar, dual-reservoir master on my '77 FJ-40. I replaced the original MC due to the same problem you outlined above: I was getting fluid moving from one reservoir into the other, due to a leaky seal in the MC.
Should have fluid in both. As disc brakes wear the fluid level will drop. Therefore I’d check your brakes and refill if needed.
Thanks, will flush, refill, and check rear brakes. Just purchased a propane heater which should help in the non/heated garage.
At least it’s not freezing yet.
