Marks4WD Crawler Box Pictures
http://www.sleeoffroad.com/technical/tz_crawler.htm
Since they relocated the fuel tank and had a 2" body lift no pics of what the rest us would have to deal with. Maybe the boys at Slee have more pics of the "in-process" part of the job.
Good luck, it should be a great setup once installed.
Awesome .. ! I don't know anything about it before. So I'm not clear how it transmit back to the tcase the fineal 3.05 reduction.
Not sure but IIRC it works on a planetary gearset system that attaches to the back of the t/case where the cover plate is that hides the nut on the end of the gearbox mainshaft.
I try to imagine how it works .. ( maybe need to see face to gears .. :D ) I always thought in a second box between your tranny and t-case ..
sleeoffroad said:
You remove in the input shaft from the transfer case. You replace that with a new unit. The shaft then goes into the crawler box, runs through a planetary gearset and then around the original input shaft and drives the original transfercase.
Trying again ..
you must use the new input shaft and the old one .. and the old one is the drive the returnet re-geared power to the stock t-case ..?
See the 4 pieces on the bottom right. Leftmost is the new input shaft, next is a coupler, next is a shaft that goes over the input shaft and last is the new gear for the transfer case.
On this is the stock setup that is replaced with the new setup on the right.
Here it is installed. The center shaft on the left goes into the crawler box and drives the planatery gears. When assembled the coupler that is 2nd to last (first photo) splines with the crawler box and couples to the inside splines (around the center shaft), which in turn transfers power to the gear and the original transfer case.
Clear as mud?
TiredIronGRB said:
Does anyone have pictures of the install, especially the gas tank and floor pan modifications?
What do you need a crawler box for? Portals just not doing it for you any more?:flipoff2:
I'm just jealous.
I am putting one in this winter. I am going to reshape the floor to make it fit. The gas mods will be easy for me.
Crawler gears in anything are amazing. I have a mini truck with them and it will go anywhere.
TiredIronGRB said:
More control in the rocks.
Yeah I know the advantages, I was just teasing you cause I'm jealous of your portals.
Mmmm......portals
sleeoffroad said:
Clear as mud?
wooooouu .. but my brain is so rired right now .. after this techinical lesson .. :eek:
:D
Thanks Christo !!! I got it !!!!
TiredIronGRB said:
Yea, but you have a diesel...turbo diesel.
Mmm.....Turbo Diesels.....:flipoff2:
