Marks Australian V8 adaptor
BC
Anyone running a Marks adaptor for 350 chev instead of the Advance Adaptors? A friend is trying to sell me his project thats he claims has one. I have a 2F thats in pieces thanks to PO and have intentions of rebuilding it but this adaptor sounds alot more straight forward than the AA. Love to hear some feedback on it.
I do believe that Advance Adaptors sells the Marks Adapter. They may private label it. If you call Gino at AA he will probably recommend the Australian made Marks Adapter.
I might be wrong.
The Marks adapter is the best way to convert to a v8 IMO. my bro and i have done one conversion and are in the process of another right now. The marks kit leaves your drivetrain in the same place as the factory did therefore no cutting floorboards or driveshafts is required. You also get the great driveability of the toy 4 speed. It also leaves your cruiser very clean and professional looking because everything is in the factory location.
Sounds too good to be true...I am debating rebuilding my basket case 2F or using this adapter. After the adaptor I would have to worry about clutch, headers and motor mounts but his project fj40 should have all this, its got a beat 327 in it now. Any details or pics on how your swap went would be appreciated. Thanks again.
The Mark's kit is good if you are satisfied with the gear ratios of the stock transmission, and want what's probably the easiest kit to install.
Advanced Adaptors makes their own kit, but they also sell the Mark's kit.
Brian, I see you have the kit on your rig. Did you do the install and how did it go? This adaptor is expensive but sure solves alot of guesswork.
Your rig sounds alot like what I'm leaning towards, 350, toy4spd and 33's with a 2.5 or 4 lift. I'm going to go check out this project fj40 that supposedly has the adaptor. Anything I should be looking for? He says it has a new centerforce clutch and the correct flywheel as well as AA headers.
If you want a very capable trail rig and be able to keep up with traffic on the pavement this is definately the way to go. I promise that you will be much happier with the v8 vs. a rebuilt I6, there is definatly a little more work involved with installing a v8 but the rewards far outweight the pains involved.
Does this cruiser you are looking at have the kit installed or did he buy it and is just waiting to install it? As far as being able to tell if it is a Mark's kit should be fairy easy just look and see if the factory 4 spd bellhousing is sitting on the stock bellhousing mounts, with an aluminum adapter bolted between it and the enginge. My bro might be able to send you some pics of his, his handle is '74 UA FJ
I've used both. If one is undertaking a V8 conversion there is going to be a lot of issues that will require above average fabrication and problem solving skills beyond that of just where to place the drive train. IE, cooling, wiring, exhaust, etc. The convenience of the Australian kit does come at a significant price, as compared to the AA weld-in alternative, IMO.
If one is justifying this kit as to save on the cost of a welder and torches, well, you can buy both for the difference in price and have the tools for other projects.
Some may argue the mounting system is superior with the Mark's kit vs the weld-in AA. Some have strong opinions on the virtually solid rear TC or 'propeller' mount and the weld-in front mounts. While I'm not out regularly trying to twist my trucks up like a pretzel on rocks, I have driven V8-powered FJ40's since the early 80's with no problems to speak with the exception of an occasional broken TC housing. Those are virtually nonexistent now that I am not out trying to regularly see how many city blocks I can smoke a 33" Mud Terrain either. Since the Orion has come out one can pick up stock TC housings for the price of a tank of gas.
That's why they make chocolate and vanilla I guess...different tastes, different abilities, different budgets.
The AA kit does not save you that much money because you still have to get driveshafts lenthened/shortened and balanced. Also the floorboard will have to be mutilated to allow for the moving forward of the drivetrain shifters.
Also either kit requires welding and cutting so a welder and torch are nessisary anyway.
The drive shaft work is $150, tops. Please elaborate on the floorboard mutilation you mention. I have never had to do anything with the floorboards. If located per the instructions, yes, the stock 4-speed shifter does come up under the stock heater. Cut, turn 180*, weld problem solved. I have had to modify the TC shifter to come throught he stock location, but hey, I like doing that type of thing and once you have done a few it is very easy. The transmission cover will need to have a new hole for the shifter and a plate riveted/screwed into place to cover the stock opening if one desires. One banana job. If these be your concerns I can appreciate that. Not worth the extra coin IMO but spend your $$ as you wish.
My personal cruiser is done the exact way you mention. But i just trailer it to where i am going to ride. I am just of the opinion if you have a nice factory fj and want to keep it that way that removing the heater and cutting/welding the tranny hump is not the way to go unless you are never going to drive it in the winter. Also bondo and paint will be required to fix the hump and make it look factory again.
I dont know of anywhere you can have two driveshafts balanced, and one of them retubed for $150. I mean actually balanced not chucked in the lathe and welded.
...I am just of the opinion if you have a nice factory fj and want to keep it that way that removing the heater and cutting/welding the tranny hump is not the way to go unless you are never going to drive it in the winter. Also bondo and paint will be required to fix the hump and make it look factory again.
If one has a 'nice factory FJ' putting anything in it other than the original engine is bastardization as far as most anyone is concerned. And that is true nomatter who's conversion kit you use.
You don't weld the hump, you cut/weld the shift lever. The hump is modified by cutting a new hole, attaching a piece of sheet metal to cover the unused hole and it is all covered with the floor mat. One may chose to, but does not have to remove the OE heater to do any of this.
For DS work Big Moe's, Fairfield AL 205-780-6206. Call 'em.
It is installed with a 327 and a spring over but the body is shot and everything is out of the engine bay except the motor, but thats the stuff I was most concerned with. The spring over has taller springs and longer shackles. He had 38's on it previous to teardown and they looked small. I don't want to mess with that and would probably sell most of it. I was concerned if the V8 is put in a good location and any other problems like cooling, steering and exhaust. I'll inspect when the weather clears and really check it out, maybe some pics.
