I have a 69 Carb and after many adjustments I have found apparently due to the seating the needle needs to be a solid needle for the float cut off - Apparently the needle with the spring can cause issues such as what I have experienced
Below is what I have found out so far - May or may night be correct but verified with Mikes Carburetors
Maybe a LC Guru can chime in as well
I ordered a Rebuild kit several months ago from Cruiser Outfitters and it actually included a needle with the spring (I'm taking this out tonight)
I have an old solid needle and have ordered another one from Mikes Carbs (see attached)
Hope this info might help others out with this wonky Carb !
For the ultra-specific 3/69 to 9/69 Aisan 2-barrel carburetor, you must use an all-metal solid float needle.
This specific 6-month window is a notorious anomaly in Land Cruiser history. I apologize for the confusion in my previous response—I mistakenly grouped this exact window into the post-September 1969 design, but you have the rare, highly distinct transition model. [1, 2]
The 3/69 – 9/69 Carburetor Anomaly
During this exact 6-month production run, Toyota introduced its first 2-barrel Aisan carburetor for the F engine. However, it used a specialized float and needle configuration that was completely unique to this timeframe: [1, 2]
Crucial Rebuild Advice for this Window
Because of this 6-month design split, standard auto parts store listings are completely unreliable for your truck.
- No Wire Pull-Clip: Unlike later 2-barrel Aisan carburetors, the 3/69 to 9/69 version does not clip the needle to the float lever using a wire hook.
- The Weighted Solid Needle: Because there is no mechanical clip pulling the needle down when the float drops, the system relies strictly on a heavy, solid-metal needle that drops down out of the seat by its own gravity.
- Why Viton Fails Here: If you install a modern rubber-tipped Viton needle into this specific carburetor, the rubber tip creates stiction against the brass seat. Because there is no wire pull-clip to force it open, the lightweight Viton needle will stick closed in the seat, causing your carburetor bowl to run dry and your engine to stall out.
- Ordering Kits: If you purchase a generic "1969 Land Cruiser 2BBL" or "1970 Land Cruiser" rebuild kit from common retail chains, it will almost certainly arrive with a Viton needle and a wire clip designed for post-9/69 models. [1]
- What to look for: You need a specialized vintage kit that specifies compatibility with Toyota OEM Float #21209-60010. These kits include the heavily weighted, all-metal solid needle. [1, 2]
- Sealing Precaution: Because you are using a solid metal needle against a brass seat, ensure the mating surfaces are immaculate. If you experience flooding, use a brass-safe metal polish on a cotton swab to clean the inner walls of the seat so the solid needle can slide up and down freely without catching.
