many questions about my fj problems
puyallup wa
ok so today i was driving my 71 fj down the road and hit a small bump and all of a sudden a loud weird noise started. it sounded like when you stick a card in the spokes of a bike. anyway i pulled over right away and hoped out to check what was going on but couldnt see anything, pulled out and the noise was gone,but i left the e-brake on and by the time i got to the gas station 1/2 mile away, my e-brake stoped working and i still didnt know what make that awful noise. :mad: :mad: :mad: :mad:
so far i have checked that 4wd works still hubs lock in and out fine nothing out of the ordinary, but i did find that my t-case seeps out oil a little (unrelated).
anyway 3 questions... is ebrake shot? or what needs replacing, what in the hell was that noise, and should i stick in some of that lucas stuff to stop leaky t-case
did you smell burning brake pads from your E-brake when you finally stopped?
if there is pad left (hopefully) you can adjust the E-brake to take up the slack.
There is an adjustment on the cable by the lever, and there is an adjustment on the drum that the rear driveshaft bolts to.
I fixed my useless E-brake by adjusting the cable before I realized there was a drum adjustment.
on the rear of the drum (toward the front of the truck. the opposite from the driveshaft) is a square *knob* at the bottom area of the drum.
this knob moves the starting position of the brake pads.
chalk the front tires good, jack the back axle up so both tires are off the ground. spin tires and adjust until you can hear the pads dragging (while lying under the T-case) back the adjustment of a little so they don't drag. that *should* do it.
this is assuming the system is in good shape...
no idea on the noise, and personally I H8 stop leak as I think it gums up important stuff.
where is the leak located? if it is underneath the e-brake drum then it's more than likely the rear tcase seal. you'll have to drop the rear drive shaft from the ebrake drum. take off the nut, pull off the drum. the rear seal seals its on the shaft on the ebrake drum. check for grooves on the ebrake drum. if so, you may try a speedy sleeve. i have used one and has worked fine. but if the groove is too deep you'll have to get a new drum.
you can adjust the ebrake by turning the adjustment on the back of it if there's enough pad left.
as for the noise not sure what that could be.
the leak/seep on the t case is directly undter case, its not coming out of drain plug, i think is comming from somewhere higher but its all acumulating nextto the plug. i dont recall any brake pad smell, but how can i tell if the pads are good enough for adjustment w/out takin it all apart. and that mysterious noise sounded like it was commin from the front left side of the axel if that helps
occured to me that this sounds an awful lot like something getting into the engine fan :confused:
yeah it seems that the fan is the culprit, wounder what got in it, ill have to take a look tomarrow. damn noise! it made me notice the leak in my t-case(good), but also ruin my e-brake(bad)
Your ebrake prolly doesn't work well because it has transfer case oil on it, too.
1. Probably, you will have to take off the drum and check. You can still get the internals for the parking brake. If the drum is toasted, you're going to need to replace it also. Not positive but I dont think anyone make a new replacement.
2. Don't know. Could be a broken motor mount that caused the fan to hit the shroud when you went over the bump??
3. Lucas stuff won't help. More than likely if it is leaking from inside the parking brake drum the drum is scored and will require a speedi sleeveand new seal installed to fix the problem.
Check water pump and alternator for play in shafts. Lossen and remove belt to be sure. Pry on engine with longest bar you can to check mounts.
so i tried to adj. my ebrake so it will work again but after it got it to hold the truck once, it stopped working again. so then i decided to try and take off the drum to check everything out, but im not sure what exactly to take off. looks like the driveshaft will have to come off somehow, do i take the 4 bolts off the drum, and four bolts off the other end of the shaft, or do i pull out the four clip things on bouth sides and drop it that way somehow? never done this before and dont want to make it more work than is nessicary thanks!
if you don't know how to remove the drive shaft I would guess you'd never be able to get the parking drum off let alone replace the brake pads and certainly not even close to fixing the probable oil leak. get a manual
that would be my guess as well, happens to me occassionally and i have a partially broken motor mount....
malphrus
I once had that "card in the spokes" noise intermittently on another vehicle. The cheap aftermarket alternator had one of the long screws get loose. It would slide forward and hit the cooling fan/disc thingy just behind the pulley, causing the noise. Then it would get knocked back into place by the time I pulled over and I couldn't see anything wrong. Very annoying.
I've seen the fan/disc thingy get loose too, which could cause a similar noise.
Good Luck.
