Manually disengaging electric locker......
Sorry if this has been discussed but the search function couldnt give me the details I needed........
I was in a predicament today where I tested the lockers "havent used them in a long time", and the front locker just would not disengage.....after turning and speeding slowing down eventually it disengaged.
My question is.....if I ever get in a situation where I deem it necessary to manually disengage the locker what would be the easiest and most effective way of doing it.
Hopefully without having to remove the whole actuator/locker.
N.B I have toyota electric lockers installed front and rear.
Thanx
Back up. Gets it disengaged very rapidly for me, when turning/etc fails.
You could do it manually, but IIRC it'd involve removing the motor.
Just FYI, but i was told that if your switch ever went out, you could literally engage and disengage the lockers with a 9 volt battery and a paper clip. It does involve climbing under the truck though. BUt this only works if the motors are working on the lockers.
Convert the Toyota Lockers to be cable operated..? So far I think it's the only one for sure on the market that can be cable operated for the Toyota's, I think another company makes electric or cable lockers but are $$$$ and an import.
Or exercise the lockers maybe once a month to keep them in working order. (Typical 4x4 manual says to put the rig in 4wd periodically to keep things working/lubed.) Once the lockers are free'd of gunk they shouldn't be any problem again, unless....
