Manifold warpage limit
I'm mating a fj60 intake to my fj40 exhaust and one of my exhaust ports is higher than the matching intake port but within the 2mm fsm tolerance. 2mm seems pretty liberal, do you'all think I should have it machined or trust the 2mm max tolerance in the fsm? I'm already planning to use 2 gaskets just in case.
Is there a warpage/gap problem or just an alignment problem? Mine was off alignment by a couple mm and it worked no prob.
Not sure about the tolerance. I definitely wouldn't use two gaskets. If it's got a big enough gap that you think you need two gaskets, I'd just get it milled at a local shop. Like 20 bucks maybe.
Here's my old one, the inside holes lined up pretty good, but you can see the outside holes were off quite a bit. Like I said, it worked fine.
Thanks, but talking about the flatness of the surface, not the alignment of holes. Guess I should get it machined to be on the safe side.
I went ahead and installed the manifolds using proper torque and sequence. I can get a very small (0.2mm) feeler gage into one of my exhause ports. Does it take time or heating cycles for the gasket to take form?
