Manifold sealing rings
Hagerstown MD
Just bought two new manifold riser gaskets from Toyota. 10 bucks each, cheaper than anywhere I've seen, I was told wholsale price due to TCLA membership. Good deal I think.
Inspected the manifold rings the sealing surface I sanded looks like some pitting from years past. the rings came off ok and the springs I cleaned and bent up a little for better ring expansion. I did not want to replace them unless I knew they were bad.
Any advice on how much expansion should those rings have, should they be extremely tight in the manifold? I thought maybe the expansion from heat might make them swell and close... thoughts comments? thanks ken
Excuse my newbishness... but where abouts on the manifolds are there any sort of ring? I just put my together and took them apart twice to fix an exhaust leak and did not notice any kind of ring. Mind you I'm running with a header and the stock intake so things might be different for me.
Some FJ's came with a 3-piece exhaust manifold - the "elbows" at either end of the manifold are detachable. Within the elbow is a spring to keep tension and a gasket to seal the exhaust gases.
