I've had a complete brake failure on with my front brakes and I now beleive I know why. I went out today to clean the debris from the soft lines in front and start applying PB Blaster as I am changing them out to try and resolve my problem. What I found was a bent bracket on the PS and a broken strain relief on the DS. It appears to me that these lines are too short for a truck running OME L shocks and using all of it's travel.
How long ago did you put these lines on? I run these same lines as of last August. Just last month I cycled and measured all of my components without the springs to see if my L shocks where being fully maximized up front. Never did I find the brake lines to be short, infact they had enough for longer shocks because my front could use a 1" longer shock.
Rick, The PS brake line bracket on the frame normally sits at what could be considered an awkward angle. Mine looks like the one in your top picture, and when I first saw it I thought it was bent too. But now that I've looked at a few others, I think that's the angle they were designed to sit relative to the frame. Your flare coupling looks like it's been leaking fluid though, or is that just the PB Blaster?
the wetness is from PB blaster. These lines where from before the taller lifts came out. The brake failure came after an abrupt maneuver while turning around on a hill. I've got a set of Slee lines coming in and a power bleeder so hopefully it will be fixed this weekend.
I went out today for a little bit and replaced both front frame/axle lines. Looks like the problem is solved. Even though I bought a power bleeder I had my wife help me bleed them the traditional way so I would notice a change from how they reacted before. Big difference and they bleed effortlessly. The brake pedal is back up at the top of the stroke. I still need to swap out the rear and will do that tomorrow and wrap up this problem.
It seems that I was drawing in air after the initial bleed and there after just pushing air in and out of the lsystem accomplishing nothing.
FWIW, not only is the Slee lines sheathed but they are an 1" longer. I'd recommend these over MAF for those two reasons.
