Man-a-fre Spacer Install ?
Los Angeles, CA
So I picked up some Man-a-fre spacers for the front of my 80 this morning. I'm in the process of installing them, they are a tight fit. The inner-diameter is tapered like the stock bump stops. So I figured I would install the spacer first and then put in the spring. Well I did that and now I'm stuck with this (see pic below). Will this "pop" in after driving around the block? I tried rocking the car and jacking it up and down no luck of getting it to pop in. Or should I just remove it and re-install?
And I don't know how you guys remove the springs without a spring compressor. I disconnected sway bar and shock but it doesn't droop that much. Maybe I just need someone to stand on the hub... which I don't have right now.
Hmm... I guess 2nd try is a charm. I was able to droop the DS easily and install everything properly. Guess I'll try redoing the PS. Nothing goes right the first time as planned!
Well fix the problem in my OP. It's really easy to droop the DS... but the PS side requires more effort. Ended up having to use a spring compressor for PS. Anyways so now both spacers fit on the spring fine but both aren't fully seated to the top of the spring housing. I sprayed some silicone and drove around a few blocks doing S... didn't work. I'll drive it more tomorrow and see what happens. And maybe go flex it out on a ramp later this weekend.
Pic of PS, DS is seated more but not fully.
Glad that you figured it out, I am getting ready to ditch the .50" spacers I have now for 1" spacers in the front.
By the way, did you happen to get before+after measurements?
ground to flare (hub center) with my previous setup: 35s, OME850, MT tube bumper, superwinch 9000 was 38" for the front.
the rear with: spare in the cargo area, warfield drawers, plus a whole mess of tools and recover gear is 40" from ground to flare (hub center).
i have a 4x4labs rear bumper on order so my rear should drop a little with that. i hope not too much.
Just a heads up for anyone doing this in the future if you freeze the spacers first they will go on easier.
Also if you remove the front bolt of the lower control arm it will flex more.
wish i knew that before. well after driving around today and flexing out on a ramp the spacer is seated better. i think it can still settle in a little bit, but you don't see the gap like in the pic above.
Mine seated ok after a few miles, I have the slee 1" on mine running 295's, still trying to get the caster to get back to normal....
Okay, now that that's out of the way, let's see the overall effect of the lift.
here's how it sits now... i'll be posting up some better pics once i get my rear bumper.
I went for the Metal Tech 1.5 spacers and as of today, I have no regrets. Paid more but they will not wear out.:cheers:
