Man-A-Fre shackle reversal
(more on the last post)
another thing to watch:
with a shackle reversal, by adding length to the shackle you may compromise the u-joint
at the front pinion. if you take this approach always check that under full droop the u-joint doesn't bind. A limitting strap in the center of the axle will not impede articulation
and is cheap insurance against pinion or ujoint breakage. If there is doubt play it safe
I thought SR from MAF is a complete kit .. but I recomended start from 0. Thta means, back to your original stup in front end. Now, instal the SR kit. finaly, compensate teh front lift in your rear end if is necesary ..
The first time that I install the SR kit, I lookdown the importance of caster shims .. !!!! rrrrrrrrrrrrrr errorrr !
