I have them on my 91 and would not recommend them. Maybe I got a bad set but mine had pinhiles in just about every weld which I fixed. shortly after that they developed a leak at the collectors. Fixed that and now the manifold gasket is leaking between cyl. 2 and 3 exhaust. I also had to stretch out a couple of the bolt holes to get them to fit.
I installed these on a freshly rebuilt engine with the head machined flat so i know the surface is ok. I can't comment on the power increase because the compression was bumped and the head portd during the rebuild. I can say that when I pull the headers off to fix the manifold gasket leak the stock manifolds are going back on.
