Man-A-Fre Exhaust Problem
Long Island, NY
Does anyone else think that this exhaust pipe needs to be at least 2 inches longer so it can clear the frame cross bar? From what I can tell it doesn't look like it will clear the body when it gets put back on. Did anyone have this issue with their bolt on exhaust exhaust for the two piece header?
TTT, where is Steve-O when you need him??
I would say that is wrong, you wouldn't have enough clearance for the tub.
are you sure it's supposed to go over the tube crossmember?
Can't make the picture out very well, but I've never seen a design that was suupposed to go over the tube crossmember. Is it possible that you've got pieces mixed up, reversed? That weld looks like one I've seen on some systems back by the taipipe. If it is maybe that piece is supposed to go over the axle?
Thanks Steve-O! for coming to the rescue! You- Da- Man!
