Making room for custom bumper
Provo, Utah
I plan to build a custom bumper this summer and I had a few goals for it. I wanted the BEST approach angle possible for an FJ80 and I wanted it to be relatively light weight and strong. I mostly do rock crawling and my stock bumper/valence/entire front of my vehicle has seen better days. I don't have the time, weather, or money right now to start my bumper so I did what I could with a sawzall and grinder. I combined the turn signals and marker lights so I could get rid of the signals in the valence. I still need to cap the voids I created with my hack job with sheet metal and finish the rough edges but I think it's a pretty decent start. Any thoughts/comments?
why did you choose to get rid of the valance? Looks like your truck is smiling at me!!
The valence was dented, bent, and pretty well hammered to death. Too many close encounters with rocks pushing the bumper into it. This way I can really get a custom bumper tucked up high and out of the way.
Your cut up bumper looks kinda cool... I think I like it. You got me thinking, maybe a strong homemade bumper with the stock bumper as a skin:idea:
keep posting.... I just demolished my valence and am thinking of doing a custom bumper w/o the valence as well. I'm planning to incorporate turn signals into the bumper, but will also use the markers as signals. How did you combine those?
I went to Napa and got an 1157 socket with three wires. I put a bulb in it and hooked it to a battery to see which filament was brighter. The bright filament (yellow wire in this case) went to the green wire on the stock turn signal harness. The dim filament (brown) went to the green wire on the stock marker light harness. The last wire was black and I connected it to both white/black wires from the stock turn and marker light harnesses. I soldered and shrink wrapped all the connections. I had to cut a little notch in the marker light housing to fit the new Napa socket but everything works great now. I kinda liked the bumper cut too but it's way too low to look good. I am considering making some brackets to lift it even with the bottom of my trimmed grill but I will probably just leave it as is.
thanks for the wiring writeup- that's definitely going on the list
I'm thinking I'll pull the valence and trim the fender sorta like you did, then use a chunk of maybe 3" by 5" 1/4"wall steel tube to run from the fender in to where the grill drops down (I don't plan to hack the grill). From there build a simple box to hold the winch. Add a chunklet or two of plate to make it look a little bit better.... and that's about it.
the 3"x5" will be laying flat- so only 3" tall in my imagination. Within that 3" I was thinking of adding some sort of blinker and maybe some rock lights or something else nifty... many plans, little money, so lots of time to think about it!
:clap: Nice work BTW.
:hhmm: For those that would like to keep the valance intact, do the blinker mod, and then use the existing turn signal sockets put fog/brights/etc/or????
Prolly wouldn't fly with local laws or something but got me thinking.
bump
Any progress on the bumper build?
