Making it Fit
I guess the PO thought if it does not fit I'LL make it fit. Scarey, But the only thing hokey I found on the 45.
This 63 rig has not hit the road yet and will db axle when it does.
I looks like the link had a larger dia end then the rod and he just spread it and clamped it.
very anal.
Since the rig you've got is a 63, I would venture a guess that he was working with the ORIGINAL tie rod, which tapers down at both ends to use tie rod ends that are the same size as the ones on the relay rods. IIRC they used that tapered rod up until 65.
