Making a Custom Battery Tray
Selling them, and are you doing both sides?
Once I get the cruiser running I’ll make the passenger side, I’ll just copy my template and switch things around to match. Maybe if I can get them made easy enough I could send some out? For right now it’s a 1 off, or 2 off counting the passenger side.
I would be interested in trying them out and giving a real world assessment.
You guys are a tough crowd!
While I happen to think the factory battery box is a good piece of engineering (I've never had the hold downs cut into the sides, guess I don't torque my batteries down to 50 ft/lbs) I also don't think a battery box takes a whole lot to be good.
The box looks fine to me. Seems unlikely that the battery will die early from extra heat because it's in a steel box.
I don't really have any criticisms. Looks nice for a home shop fabbed battery box! I don't think my welds even look that good anymore lol.
So are these sized for a group 31 or 27? Currently I am running an Optima SC31DS but will be moving to a 27M-AGM from Interstate.
Throw one of those battery heat barrier covers on it if you’re real worried about heat?
Honestly dude, I was not worried about heat until the feedback I started getting 😆 It’s a little something I like to call “peer reviewed research and design” or PRR&D.
Took your comments back to the drawing board. Definitely don’t want to cook this new battery… Added side ventilation holes (very large) as well as two slats to add to the bottom of the tray for more air flow.
Adding to comments about insulation from engine bay heat, the OEM battery trays are sealed against the hood creating an isolated compartment to keep the battery less exposed to engine bay heat.
I think this is a good feature in extremely hot conditions, but also can't remember any other vehicle I've owned that has the battery so isolated.
Tray looks good, having somewhere to stash fluids is a win for sure. My work truck has room behind the headlight for a 1 gallon oil bottle. Makes it super easy to check and top up the oil while refueling
Everyone is an expert, no shortage of peer reviews, maybe a shortage of research and design though . . .
:hillbilly:
If you're worried about heat, an infrared temperature gun would tell you how hot the battery is getting
It's on the opposite side of the engine bay to the exhaust, and getting some airflow from around the grille/ headlight etc.
No different to 99.9% of vehicles on the road
I like the toyota trays since they wont corrode etc. The hold downs are definitely a bull**** design - especially for an offroad vehicle that deals with bumps and corrugations etc.
This was my 'fix'. Some steel rod and fibreglass mat and resin. Then using some decent hooks and over the top bracket. The hooks mate with the steel rod versus ripping through the tray material. Did this for both the main & aux trays.
The toyota trays are easy to 'repair' with fiberglass mat and resin.
cheers,
george.
Major repairs down to this tray - holes patched, cracks repaired.
Great minds think alike
This is exactly what I did to a new tray. 😎
Installed the battery tray. If you can’t tell I’m stressed. Getting really close to starting this “rebuilt engine” I put back together, and the potential for failure is high. Installed a dope little adapter Ryan Eklund makes to help the alternator with the AGM battery. Firing up soon…
