I’m 5’9” with a tiny pecker
Welp, you can always compensate with a 7" lift and bolting 1/2 the ARB catalogue onto your truck . . .
Great advice but between my 80 and my Snap-on dealer my prison wallet is always barren…. So 7” lift and ARB is out of the question.Welp, you can always compensate with a 7" lift and bolting 1/2 the ARB catalogue onto your truck . . .
Did you mistype your msmts? 3/4" at the rear seems like nothing, given a "jacker" was in the mix before.Hey guys,
I finally got around to installing the Jass Seat Lowering Brackets, and I'm very happy with the results. Before installing them, I had the seat jackers on the front, and here are the measurements I took of the drivers seat all the way back and in the lowest position:
- front of seat to ceiling: 31-1/4" of height
- rear of seat to ceiling: 38" of height
After installing the lowering brackets and removing the seat jackers:
- front of seat to ceiling: 32-1/4" of height
- rear of seat to ceiling: 38-3/4" of height
I never really liked the additional seat height after I installed the seat jackers and now with both removed, the seating position is much better for me. I always felt like I was sitting way higher than any of my other vehicles in the LX...now it feels as it should. Post install, I've electronically raised the front of the seat a tad, and it feels so much better. Plus, getting in and out of the vehicle while it's running is much easier to slide my legs under the steering wheel with everything in the stored driving position.
Install was easy...followed their supplied instructions and everything went exactly how they described. I did use blue threadlocker on the bolts/nuts they provided to secure the new brackets to the slider rails. Lastly, because it does lower it so much in the rear, I used the angle grinder to take about 1/2" of the outer plastic trim of the seat just in the very back corners closest to the b-piller, because when the seat was all the way back it was causing the outer trim of the seat to bow out from hitting my carpet/husky liners. I also had to trim the husky liners so it didn't interfere, as well.
Otherwise, simple straightforward install, and I'd highly recommend them to anyone that thinks the seating position just feels too high, whether you're tall or not. It now feels much more normal and comfortable to me.
If anyone's wanting some seat jackers, I'll sell my set for $100 shipped.
Chris
Nope, that's what was measured. It's supposed to lower more than that, but that's what I got.Did you mistype your msmts? 3/4" at the rear seems like nothing, given a "jacker" was in the mix before.
