Major problem, please help.
Cuba, MO
Okay so I was lazy and had the oil changed in the 80 at a local Jiffy Lube. Please look past this error in judgement.
I drive away. I go to make a left turn at an intersection and the truck dies. I am still rolling so I put it in neutral and it starts right up like nothing happened.
It has happened a number of time over the course of the afternoon. It also lopes around badly in reverse. Sometimes when I start it and put it in reverse it dies immediatly. Other times I have to keep the RPMs up just to back up.
Right hand turns have no effect.
What is my issue?
Okay I am now looking under the hood again. I notice there is two hoses entering the valve cover. The hose on right as you are looking at the motor from. The frnt is easily removed by gently pulling and the plastic "housing" it fits in is cracked.
Could this be the issue?
Hmmm. What about a possible ground issue? I don't know how they could have jacked that up with an oil change... but we aren't supposed to point out your error in judgement so... :) Ha ha. Sorry. HOpe you fix it.
94 model. Not sure about engine type. I'm not up on the 80 series like I should be.
I'm thinking an issue related to rocking of the engine (right turn and reverse rock/torque it in the same direction, right?), either vacuum leak (intake hose?) or grounding as pookie says...... but what do I know, I drive a Besser.
Well it is the left hand turn so the engine would rock toward the passenger side fender. I'm not sure which way the engine torques in reverse.
Get on the ringer and let the shop that did the work know asap, before they claim all types of excuses. No I probably wouldn't take it back there for the fix, but if they messed something up I'd hold them accountable.
They tore the intake hose I did the same thing when I replaced my filter it cracked the intake and I did not know it at the time.
But when I went to work the next day and made a left hand turn the truck stalled all the way to work.
There is something about cracking the intake under neath and the body torque when turning left that opens the crack in the intake and makes it stall.
I will bet any amount of money that if you take a look at the underside of the intake hose by the ribbed section that you will find a crack.
And if you do just duct tape the heck out of it and order a new one from CDan.
That is what I did.
well guess what? The intake WAS torn. I say was because now it is in two pieces. I couldn't see if it was torn. I was trying to take it off and I now have a two piece intake. Thanks for the help.
No dice at Oriellys or Autozone.
Lunyou.
Kidgloves big thanks for the exact prescription for my truck's illness.
Just give CDan a call at American Toyota, Mud discount will save you some good coin on a new OEM one.
Did you ask them to check the air filter?
If not I would ask the dumbasses for a hundred-dollar-bill so that you can fix what they wrecked.
General question since I have not been to "Jiffy lube"
Do they automatically check air filter w/ oil change?
Good luck, Lunyou.
BM (before mud) I took my 80 to a Jiffy Lube because I had a coupon and didn't know better...... After, It just ran wrong and dripped small amounts of oil. I thought since the truck had some years on it this was normal. Ive since changed the oil (m1), oil filter (oem), and air filter (oem)back to OEM, all my little oddities on how it was running and dripping have ceased and running well with close to zero drippage. At the time I figured any tuneup was better than none, I was very wrong. Glad I didnt purchase the extra $360 of stuff they said was was wrong and needed to be fixed, tanny flushs, rad flush, etc... (dont remember all the items and threw the quote in the trash)
F J-Lube.
