Maintaining a 2F-ETI and a 40
Melbourne
I decided to start a second thread for as it says Maintaining a 2F-ETI along with the 40 itself.
Building a 2F-ETI <--- Link
Whats in store
Well the new Exedy Safari Clutch is in and working, lets see how long it lasts. Fitted by ARB but I can get on the boost now :)
Swivel hub rebuilds.
Mechanical Fuel pump oil leaking from where it mounts.
Fit new Spark Plugs Bocsh Not a simple task.
Rebuild the rear tail shaft currently running the spare. Done 20/07/2019
Rear wheel bearing rebuild.
Rear ARB diff breathing oil up the air line.
Strip and rebuild the Warn HighMount.
Engine oil change and filter.
Engine Tune
New set of Tyers
Small coolant leak from the thermostat top housing pipe work.
New drivers seat.
Fix high beam
New LED head lights
New LED front Indicators
That should do for starters. Were my Wallet :-(
Subscribed to this too...The original was epic!
Q
Number of teeth on the worm gear of a 2F/3F/3FE dizzy.
I think its 15 but don't have a dizzy to hand.
Intercooler out
Dizzy out
Plugs out
Found a poor connection to the Temp Sensor keeps dropping out to -45C.
Time for some new HT leads too.
Will be a while here. While I replace the bush for the steering column and few other bits that are accessible.
On the flywheel there are 2 marks close to TDC
The manual says 7 degrees BTDC is the line. Is the drill mark TDC?
I think that's backwards, the line is TDC and the BB is 7 or 8 degrees. I could be wrong.
Upgrades.
Now with side/park lights built in I can look for a LED indicator to replace the last of the old lights.
In and hooked up. Few minor issues as earth is not earth ( green and yellow) but the side lights. Black is earth.
Intermittent high beam from before install. Broken wire in loom.
Well it was not the dizzy.
After knocking the plug while ruff idling trying to check the timing she stopped dead.
TDC set with strobe and wires twisted together and she start off the key every time.
Now just to solder a few bits together and she's purring like a kitten again.
Hey Matt, I just logged on (haven't in years) to try to find your email address- great to see you got your 40 back! My 42 is still skulking around marking its territory. Where did you buy? We bought in Nth Warrandyte. Will have to have a beer sometime. Wanted to ask you about cooling components for a small oil cooler for a motorbike. Cheers, Hans.
Well I had not noticed but on close inspection the oil cooler has been repaired before with liquid metal cement.
Grrrrrr
However I have a Dremal :-)
All ready to be repaired properly.
Been a while but Oil cooler replaced thanks to Dan Hull and his spares stash in Cali.
New Dizzy, Coil pack and Spark plugs fitted along with a new radiator, tiered Toyota wires replaced and Dizzy hard wired no connector at the dizzy one less plug to go wrong.
New 35" BFG Muddies
Tomorrow she back for a tune on the dyno at CSM in Seaford dropped in today.
New Led indicators. Functional will keep looking pics soon.
