MAF 4+/ 3" kit
Abbotsford, B.C.
Looking into lift kit options. I've been doing loads of searching on the different set ups. My favorite by far is the FOR kit but the base kit is a little more than I want to spend.
This kit looks like a good option. Can anyone give me feed back on this kit?
Use of my truck will be DD, family vaction mobile including towing a small travel trailer, wheeling maybe once every 2 months. Type of wheeling is Pacific Northwest; mud, roots and logging roads. No real rock crawling.
:cheers: in advance
I have a 3/2 level stance MAF4Plus+ that the previous owner put on...it's a decent lift but drop brackets for the trailing end (frame mount side) of the front control arms is NOT the way to go. (IMHO) just a PITA as it relates to hanging up on rocks and complicates the addition of sliders. Get your caster correction through bushings or slee caster plates.
What sliders do you have? What sliders did you try to fit?
I am running the 4"/3" level stance kit from MAF and I am extremly satisfied with it. It rides awesome, doesn't pull at all. To me that's the way to go. Here's a pic:
Now if you dont have a front bumper and a winch is going to look a liiiitle bit higher in the front, but since I have both it looks perfect.
With that kit you won't need anything else, it's just install, align and drive..
Your truck looks great! That's about he desired height/ stance that I'm looking for. Plus if it performs well then that seems like a pretty good deal.
Have either of you had any driveline vibes with this height?
Perroetaller, what did the total amount set you back for that lift, if you dont mind saying. You can PM me if you want. I am curious as to the overall price, including everything. Looks great, by the way.
When you say a 4"/3" lift, are you saying J's in the front and regular heavies on the rear?
what size tires you plan on running? if its 285/305s, id stick with a heavy+front spacer combo. if its 315s or 35s, id go with the 3.5~4". isnt the maf 4+ just a J kit with the drop hanger for caster correction? id prefer plates over a drop hanger, but different strokes for different folks.
imo, anything over 2.5" makes 285s look too small in proportion with the rest of the big 80. my 315s albeit down to about 30% look teeny tiny on my 4".
I don't have the sliders yet but I'm looking at Metaltechs with cat protection...furthermore if I did find a way to make them fit, it would further islolate the dropbracket as lowest point to make contact with. I have had the truck 3 months and have hung up on them as many times
Did you need a double car dan shaft?
d0ubledown, for tire size I would like to run 2 sets of tires. I'm planning to tow a 17 foot Bigfoot trailer this summer so I'd like to run stock tires for that. I'd also probably run the stockers for most of my around town driving. The second set of tires will be a set of fairly agressive 35's
So from what your saying, I think I should be looking at a 2.5" lift. Do you think I would need to add a set of spacers/ packers to clear the 35's? Also, do you tow with the 35's on?
Thx
