MAF 3fe ignition
Silver Lake, MI
Hi I have 92 3fe 80 was wondering if anyone here had any experience with the MAF hi perf ignition kit. I am just curious if i this kit would make a noticeable difference in mileage or performance over a properly tuned stock ignition any feedback would be appreciated did not find much on this in this or the 60 forum thanx in advance.
Generally I can give this set a thumbs up. Here is my personal experience:
The components of this kit are made by Performance Distributor. I have the ignitor portion of this kit on my FJ-62's 3FE. I run it with an MSD high vibration coil (which I already had and which Performance Distributor said would work just fine with their ignitor) and Magnecor wires.
I can't speak to the impact on an engine that has a lot of miles or is only in so-so condition. On my 3FE engine, which is rebuilt and is very strong, I noticed a distinct power improvement. This was particularly noticeable on the hill that I use to do seat of the pants testing (full throttle, 2500+ rpms).
One other caveat that I would offer is that I've heard that the ignition in FJ-80 3FEs may be stronger than in FJ-62 3FEs. Supposedly the plug gap is larger possibly indicating that there is already a stronger spark in stock FJ-80 3FE ignition.
Also - if you have not already done so you might consider advancing your timing. Depending on the octane that you are willing to run and the condition of your engine you may be able to go anywhere from 2-6 degrees advanced from stock (9-13 total of static base timing). Obviously start very conservatively and be very attentive for detonation. I run a J&S Safeguard on my 3FE so I can run extra timing and know that if detonation occurs the Safeguard will pull timing to keep the engine safe before the detonation would even be audible to my ears.
Most people say stay with stock toyota. If it was me and I had the money available i'd say give it a whirl and let us know. But it is up to you I doubt you'd really feel a difference unless your stock ignition system is starting to konk out.
Good info thank you, My motor is 200k but very strong running has recent tune up good idle etc. Never had an ignition issue with it. But as you all know with a 3fe pushing a tank every little bit helps. I have opened my exhaust up with dual 2" off cats to flowmaster and 21/2" rest of the way. I use the rig for towing here and there and every little bit helps appreciate input and would love to hear anyone elses thoughts.
