M101 v. M 416: what are the differences as I´m slightly confused
Living,
Thanks for posting up that link, it's a good one.
I know I have several more that could be useful when I get a chance to dig around for them. In the meantime, anything else that people know about that gives manuals, data or historical info will spice this up for future reference.
Well, if you want links, there are two useful ones right on this very website:
http://www.ih8mud.com/tech/pdf/trailer/m100-m115.pdf
http://www.ih8mud.com/tech/pdf/trailer/m416.pdf
Guys,
These are great links. I posted up this thread because I wanted to learn about these trailers. The general response and these links are great. The funny part is more than twenty years after my discharge from the Army here I am again, reading field manuals.:doh: Thanks.
:cheers:
Living,
X2. This thread is becoming a great reference for trailer noobers like me. Please keep the reference links coming.
Thanks,
John
I have a question someone here might know the answer to. Will the wheels from M100 work on the MBT/T-3? Mine came with what someone told me were 15" ford rims. I would rather have 16" rims I could mount 7.00 16" NDT tires on. I know the 6.00 16" are stock but the 7.00 are easier to find. Not looking to spent the money for combat rims. Not sure if there is a non-combat rims for the era? I know the military jeep from the same time will have interchangeable rims. Also know the M416 rim the hole in the center is too small.
Here are a few links of interest to the 1/4 ton trailer crowd.
A forum oriented more towards restoration, but I like to keep things looking fairly toward the issue side of style. I'm not a member, but the archive there is useful:
Trailers - Steel Soldiers::Military Vehicles Supersite
If you want to upgrade your lighting and retain that authentic look:
Trucklite Military LED Lamps - Truck Lite
TruckLite and Grote both have rear lamp and other lighting in modern LED flavors, but pricey if you just want lights to work;)
A link to the Southwest Trailer conversion hub to adapt the M101 CDN's from the mil pattern to the 6x5.5 Land Cruiser pattern:
http://www.southwestwheel.com/store/showproduct.aspx?ProductID=247&SEName=l0655lb3e
In case that link gets broken, it's for SWT# L0655LB3E.
10" hub/drum, 6 studs 5.5" bolt circle using L68149 inner and L44649 outer bearing. Contains inner bearing, outer bearing, seal, grease cap and lug nuts. (84 series Spindle)
Note that the 3500# capacity 84 series axle can be ordered as replacement for earlier pattern trailers. The brakes on the M101 CDN are Dexter pattern 10" drums.
M101 CDN usually don't need a new parking brake handle, as they can be freed up by juicing them repeatedly. Earlier trailers may have an in-op brake lever or it's missing entirely due to being previously deleted by a PO. Don't pay too much. Cable is extra, but probably something easy enough to scare up:
Emergency Brake Handle [217601] - $4.95 :: Colemans Military Surplus LLC - Your one-stop surplus store with Army/Navy products for hunting gear, camping gear, emergency products, and survival products
I saw swampman has a new prime mover, but his trailer lid pattern is popular and easily adaptable to the other 1/4 ton trailers:
https://forum.ih8mud.com/trailer-tech/359042-m101a-cnd-lids.html
A M100 page:
TRAILER, 2 WHEEL, 1/4 TON, M100
Bantam T3-C page:
The Bantam T3-C Page
Enough to confuse any lover of military terminology (but a good reference):p
List of U.S. military vehicles by model number - Wikipedia, the free encyclopedia
OK, back to work for me.:crybaby:
The rims are the same pattern as WWII and post-war Jeeps... 5 x 5.5". with an approx. 4" hub (I think the correct measurement is 4.2"). So yes, M100 rims will fit the MBT/T3 series. In fact, the same rims were used on the post-war civilian T-3C trailer.
You can mount either the 6.00x16 or the 700x16 tires on these rims.
If you have 15" Ford rims they should have a script Ford in an oval stamped on them.
More links:
Some repro and NOS parts for the M100/M416:
Trailer Parts
But also a reminder to check around on prices. That parking brake lever is a whole lot cheaper at Coleman's -- or maybe I'm missing something?;)
More trailer parts,scattered across multiple pages:
Military Vehicle Parts - Army Surplus Warehouse - Army Surplus Warehouse
More parts for MB, M100/M416, etc:
Midwest Jeep Willys - MB Trailer Parts
And lots of generic electrical and other items for restorations or just because you want it that way:):
Military Trailer Parts, M101, M103, M105A, M116
Military Vehicle Lighting, Tail Lights, Marker Lights, Bulbs
Another tech manual link that covers a number of trailers, inc. the M416, Technical Manual TM 9 2330-251-14 Trailer, Cargo, 1/4 Ton
Technical Manual TM 9 2330-251-14 Trailer, Cargo, 1/4 Ton : Department of the Army : Free Download & Streaming : Internet Archive
One fellow's M416 project link/info page:
Jeeps Only: Project 1 - Raptor
Another M416 project:
M416 Trailer
Hey, someone else thought about making a comparison between the different M#s a sticky:cool::
G503.com Message Forums • View forum - Trailers 1/4 ton
This link, in particular, gives a direct comparison to distinguish different ones from each other:
G503.com Message Forums • View topic - MBT/M100/M416 comparison
M416 Yahoo forum:
M416 : M416 1/4 tn Trailer User Forum
Now this is a different take on what to do with an old 1/4 ton trailer. Some guys have Adventure trailers and other guys have adventures with meat. Put the two together and it would be a hit at just about anyone's campsite:D:
M416 Military Trailer into smoker/grill - SmokingMeatForums.com Community
Yet more!
A really good write-up on evaluating, buying, and restoring an M416, but lots of good info regardless which 1/4 ton trailer you have:
M416 Trailer Project
1/4 ton trailers from the Canadian point of view for all our Canadian friends and trailer fans:
Trailers
French 1/4 ton trailers:
Bantam 1943 Jeep trailer - modified for French Army use
If you like yours modded, dieselcruiserhead's M416 build:
1966 Military Trailer ("Built" kitchen, independent suspension, roof top tent, etc) - Hazard Assembly - Adventuring & Dirtbag Adventuring
To help fill your mil trailer (and other vehicle) reference shelf:
Portrayal Press - Military Vehicle Manual Listings
OK, back to working on the 80 camper conversion:)
Talking to someone to day I found that they had 15" wheels on some of the early jeeps. Is this true is there a chance my 15" wheels came stock on this trailer? 9/43 Willys MBT. Anybody have source for the non combat 16" wheels? I plan to use it behind a FJ25 with stock 16" wheels
