So the 80 is getting new tires soon (315-75-R16 MTR's) and 2 of the old ones are still in good shape after 50K miles (~50% tread - even wear) and would make great trailer tires. AND I've been leaning toward doing the SOA to the M101.
So the question is ....... What wheels have you all been using that have the same bolt pattern and backspacing as a stock 80 (other than the obvious 2 more stock 80 rims). Any clearance / rubbing / spacing issues after doing the hub swap. I'm planning to use a hub kit such as.... https://www.southwestwheel.com/store/p-247-l0655lb3e.aspx ..... (Thanks to desertdude for the link -
Also - post some pictures if you have them.
Many Thanks!!
)Also - post some pictures if you have them.
Many Thanks!!
