Brent, nice trailer. What kind is that?
Thanks - M101CDN with a new paint job. Did rather nicely for it's maiden voyage.
How does it pull behind the 80? I have heard that the knock on the military trailers is that they are really heavy to tow. Yours looks smaller than most- is that the CDN part of the m101?
Regardless, I've got the cruiser wired for a brake controller, so it's a saftey thing for me.One other PITA item - washed the truck and trailer and when finished, as I usually do, check the tire pressures and the air bags. DS airbag was nil so filled it and PSSSSSSS - leaking air. Sounded like it was coming from the top of the bag in the coil. Could be and hopefully just the air line has worn out after at least 5 years or more in there. Still a PITA to repair. Need to completely unload the coil to get to the top of the bag and that means the hi-lift since I don't have access to a garage with a lift. Shiat! At least the M101 isn't heavy enough to really need the air bags like the troop trailer did.
If you want to drive to Torrance you can use my lift... But it is probably easier to use your high lift...
