LX570 rear brakes dust shields cost insane. Why?
il
Rear dust shields for our vehicles are insanely priced at over $700 a piece. That is 10 times higher than front dust covers.
They are located on the parking brake assembly parts diagram and are listed as parking brake backing plates. Still can not believe the cost. Even Japan imports are over $1K.
About to do rear wheel bearings and wanted to replace rusty dust shields as they require axle removal to swap out.
My only clue on the high cost is that they are sandwiched with the rear bearing assembly to the axle housing and are structural in the way and are attachment point for parking drum brakes. Still do not understand insane price.
On top of it aftermarket sources are scarce.
$287 USD out of the middle east: Parsouq
$283 USD out of the middle east: Partsnext (but out of stock)
$228 USD out of Japan: Impex
$325 on Ebay
$206 CAD (about $150) from Canada: Discount OEM Toyota Parts and Accessories - ToyotatownPartsDirect.com - https://www.toyotatownpartsdirect.com/
In all cases, part number: 4650360221 was searched. Other side (left) is part number 4650460361.
Indeed, these are not simply stamped parts. There's a bit more to them.
$325 on Ebay
$325 on Ebay
That Canadian discount is sure impressive, I did look hard and maybe my big mistake but endup grabbing last set of aftermarkets available from Amazon, $150 for a set.
Hmm…..That’s $72 each. Somehow I can’t imagine those being OEM quality? This is what the OEM parts site reads:
“The Parking Brake Plate Sub-Assembly Right Hand (#46503-60230), a crucial Drive-Chassis part within the Parking Brake & Cable system, serves a primary role of providing a secure foundation for the parking brake mechanism. It functions as an anchor point for other brake-related components and thus plays a critical role in the effective functioning of the parking brake system.”
That’s a Toyota part number, BTW.
I realize, calculated risk as I’m under time pressure, I always buy OEM parts but close inspection of the part shows Stamped sheet dust shield and HD steel Backing plate attached to it, close inspection of aftermarket part photos (see attached) shows just the above so risk worth taking. OEM dust shields are very prone to rusting and once they do they deform badly and rub against rotors so it is not perfect design to start with. How much worse can the aftermarket be - Im about to find out.
Toyota sheet metal parts like shields and under covers are always prone to rusting, I once replaced my rusted engine undercovers with OEM but after matting the surface gave new item 3 thin layers of black rust protection paint and they are still holding up like new.
Welcome to the world of tariffs. Part 46503-60230 (2016 and we're backing plate). USA discounted price $477. Canadian $180
@airdzi @chubot How are the aftermarket plates holding up? Anyone else who has installed these?
I recently replaced front and rear suspension on my truck and my aftermarket rear dust shields are still looking solid
I ended up going with an OEM set from Impex Japan for ~$565 including shipping and tariffs. Note that these are a bit more than just dust shields, as they have a large structural component that carries the rear brake caliper and all the parking brake hardware.
I'll add that OEM parts are nice and you know the fit is good, but the paint they put on these parts is a joke. I always give them a full paint job with Rustoleum before installing. Sand, wipe with acetone, primer, then 2 coats of satin black, let cure for 2 days before installing.
I just bought a pair of lower control arms to replace the rusty ones on my Tacoma, and the factory paint is already falling off the welds, out of the box. Pathetic.
Looks like Aisin offers an aftermarket option too now for $170 for pair if this is a legit listing. Went ahead and ordered it but unfortunately says delivery 8/22-8/24. Going to be without this vehicle until part comes but have a backup 3rd gen 4Runner with fresh axle seals and bearings.
