- Joined
- Nov 17, 2008
- Threads
- 45
- Messages
- 258
Bumping this thread for anyone with similar audio issues. My radio unit died completely after occasionally scrolling through inputs for a few years. Went through the FSM diagnostics including the wiring harnesses and steering wheel controls. I disassembled the unit and reflowed a few of the solder joints that looked suspicious. No luck. I couldn’t find a junkyard part… wonder if the failure rate is high? Took a gamble on a used part from a similar spec LS460 (Mark Levinson, DVD Changer) and it worked. Posting details here in case anyone needs to do the same.
Original:
2010 LX570, Radio part number 86120-60G10, Faceplate code P6520
Replacement:
2010 LS460, Radio part number 86120-50P90, Faceplate code P6522
You will need to swap out the exterior faceplates, metal faceplate underneath, and the mounting arms/brackets on the sides.
My failed unit was made in China while the LS unit was made in Japan.
Original:
Replacement:
