LX450 VSS (speed sensor) Wire??
Pleasant Grove, Utah
Is the Lx450 VSS wire the same as a 95-97 80? I checked out Slee's Truspeed installation page and it shows the wire as the #1 red-orange wire just behind the glove box... it the LX450 the same??
any help would be great.
thanks
Bret:cheers:
The quickest way to tell would be to refer to the EWD for your '96 LX. If you don't have that then look up Ken's (ID=Romer) "Yellow box" install which is probably in the FAQ. He has an LX and he documented the location of the VSS wire. Probably has nice pictures also.
-B-
I searched the information from Romer, But can't find any LX450 info, he has a link to a great write-up but it is for installing a Yellow Box on an 80.. The really sad thing is that I found the info on here a month ago, I wrote down " red-orange behind glove box".. So when I removed the glove box and found 10,000 wires, I decided to get a second opinion.
thanks for the help..
Bret
Red wire w/Orange stripe. If you read Ken's article and the Slee article and Woody's write up, you can deduce that the LX is the same. Ken has an LX and he said he followed the instructions in both of those prior write-ups.
The red wire w/orange stripe is the VSS signal in your LX.
-B-
From what I can tell it could be red orange.. red green or Crutchfield says that it is BU/WT Blue white?
we shall see
thanks
Bret
-B-
I am very happy to say that it was the red-orange wire after all... I know have a little faith...
thanks
Later
Bret
