LX450 electrical gremlins
Great White North
Hoping someone will have an idea as to WTF is going on with my rig. Recently replaced my valve cover gasket, spark plugs, spark plug wires, distributor cap and rotor. After fixing all this I noticed once I was at operating temp I had an intermittent miss fire at idle and sometimes under part throttle from a stop. I have a buddy with a fancy SNAP-ON diagnostic I-pad looking thing so we hooked it up and are monitoring some data and my coolant temp and intake air temps are spiking. Coolant temp would stay at 170ish degrees then for a split second go up to 302 degrees and back down to 170ish. Same with intake air temps steady at around 80ish degrees then spike to 180 degrees then back down. We keep scrolling down through the data and with the the trans in park NOT moving vehicle speed sensor would read 0mph then spike to 20mph. I put on some cheap NGK spark plug wires so we thought maybe they were inducing voltage to the harness directly underneath the coil wire. Key on, engine NOT running with the coil wire unplugged everything is still spiking up and back down. I was just trying to diagnose a miss fire and now I have all these sensors reading funny. No idea if it was doing all this s*** before I did my repairs or not. Does anybody out there have any ideas? Much appreciated.
Got a SuperCharger? I have seen surprising amounts of damage to main wiring harness between EGR pipe and right angle turn at firewall, next to heater valve. Caused by combination of EGR/engine heat and linear stress. Caused by failure of th P O's mechanic to follow TRD instruction to extend certain sub-harnesses instead of just jerking on them to stretch them all the way to the throttle body. Wiring harness becomes much less forgiving as it ages.
No supercharger. Going to check the ground I took of for the valve cover gasket tomorrow.
FIXED!!!! For anyone that was interested seems the idle control passageway or whatever in the throttle body chose to clog up right after I was doing my tune up causing a very rough idle/missfire. Funny data from the scan tool was because of an issue with the scan tool itself. 4.5 is purring like a kitten
