LX450 Baloo
Houston TX
I find myself in another 80 series. My first one was a '96 Triple Locked that I bought from HS teacher bone stock with 165k miles about four years ago. After wheeling IFS and folding tie rods and snapping CVs regularly, I decided to get into another solid axle.
I picked up this LX450 with 244K miles, '97 triple locked. Fairly extensive maintenance history, with no engine oil leaks. Typical wear and tear for a vehicle of this age, but overall excellent condition.
The initial plan on this one is to do what I should have done on the last one, and focus funds toward base-lining and PM before spending cash on modifications. I plan to get the HG done and head machined for piece of mind.
**The LX currently sits on old man EMU heavy fronts and medium rears. I removed the 1" trim packer in the front to delete the small squat. I do plan on building my rear bumper on this one similar to the GX470 I built, but only if it's tasteful. Otherwise, I will go the 4x4 Labs route on the rear.
Short term build goals are to keep COG low while being able to fit 35's, and get sliders and a rear swing out on the rig. Aftermarket wheels would be a plus if I find a fair deal, but not priority right now.
I'm going back and forth on cladding delete or not. I know inevitably I will lose a fender flare or two on the trail, so I may delete now and rhino line two tone. Question is do I aluminum tape, or weld..
Anyway, this will be a slow build but I plan to keep this thread updated.
Welding that thin of metal can be a pain unless you know what you're doing.
The tape is quick, but i've seen the rhino lining flake off where the holes are taped.
Removed 1" front spring spacer, rattle canned the wheels black and clear coat, and installed 1.5" wheel spacers front and rear until I decide on wheels.
Also installed Old Man EMU steering stabilizer
Next is to get the HG and other "while you're in there" items done.
Why did you install 1.5" spacers on stock wheels?
I havent decided on a set of wheels yet.. and the SCS wheels i've had in the past, always end up scratched up. No real point in spending hard money on wheels IMO. Purely for stance and arguing for or against premature wheel bearing wear.
