During long periods of full load (climbing mountain passes on the highway), coolant temps would slowly creep up, forcing me to down shift and slow down. Now that the AC is working, I was worried this would only get worse. It was time to swap out the all metal CSF radiator for something with higher heat rejection.
The 3FE, 1HZ, 1HDT 80 series radiators are the same. The differences of the 3FE and 1FZ radiator:
-3FE outlet is 1.5” diameter, 1FZ outlet is 1 5/8” diameter
-The inlet and out are in slightly different location horizontally however, it’s less than 1/2” difference
-The two bosses the fan shroud bolts to on the upper tank and the two tabs the fan shroud sits on are all in different locations horizontally
-3FE radiator doesn’t have the 5/16” nipple on the top tank that the 1FZ radiator has
-3FE radiator cap is on the left side, 1FZ is on the right side
-I can’t comment on the transmission cooler line differences since I have a manual transmission and they weren’t on my radar
A 1FZ radiator with the different fan shroud mounts could be used in my application. The coolant inlet to the 1HZ is 1 5/8”. Wizzard cooling charged me $774 + $46 shipping for their 1FZ radiator,
1993-1997 TOYOTA Landcruiser Aluminum Radiator, with the trans cooler removed and the upper and lower fan shroud mounts moved to my specs. Ron Davis quoted me ~$1200+shipping for a FJ80(3FE) radiator. Wizzard cooling was easy to work with any they had a fast turnaround time. The radiator was at my door within a week of me giving them the thumbs up to make it.
What it looked like out of the box.
I sanded these rough edges smooth around the mounts.
The fitment was poor.
This picture was taken with all the mounting bolts installed but not fully torqued. After fully torquing the mounting bolts, it sits slightly straighter.
At the end of the day, the Wizard Cooling radiator cools way better than the brass CSF radiator it replaced. If it proves to be durable and continues to do its job, I’m happy with it.
