You can always rip it out and fab up a rear storage solution. It will probably be cheaper and alot easier to do than to try and source the carpet. I would go for the rear storage if I were you. But if it's not what you are looking for, you can always call CDAN at american toyota 800-432-6668, he will guide you in the right direction.
Carpet for cargo area all Gray/Brown and Oak available. $150
Carpet for inside wheel well all Gray/Brown and Oak available. Sold each. $75
Tailgate carpet panel 91-97 No stains, all colors. Nice shape. $100
It looks clean. Shiney paint. This was a wierd one. The corosion is limited to the bolts/screws/tie downs that were in the area. The paint/body seam filler/ and rubber seems to be OK.
I would make sure you neutralize the chlorine that is there. Baking soda wont work, they are both alkali. Chlorine bleach is not an acid. But damage could still be going on.
Water is PH neutral so you can't go wrong there. Dawn I would venture wont hurt to use. I would rip out the carpet and then hose off the cargo area best as I could. Then proceed with soapy water.
Scrub the area down really good with soapy water. Get new carpet from Cruiserdan.
There are a couple of options for the tailgate. Some have covered with a solid piece of high-strength aluminum. There is a tail-gate bin option that is available though the guy building them is back-logged so it will be several months before you could get one and they are spendy. Of course, you can simply replace it with more carpet which is what most of us would do.
Best practice is to do an annual cooling system flush & fill with premium coolant. If you use Toyota Red then stick with it. If you use Prestone green then stick with that. Do not mix coolant types. Avoid any and all "long-life" types of coolant (e.g. Dexcool orange). It is OK to switch from red to green if you are doing a good flush. (emphasis on "good"). Experimenting with coolants in our trucks is dangerous since we know that cooling system problems exacerbate the HG failures. Keep the system in 100% operating condition and you may prolong a HG failure indefinitely.
