LX 570 - SS3 Fog Lights (w install)
I have the SS3 Max fogs in my LC200 and am blown away by how bright they are. More powerful than my low beams. They are wired into the OEM fog switch so they are only on with the low beams. It’s kind of a step down when I flick on the high beams because I lose the DD fogs.
Daytime shot so you can’t see the light output.
Hi, I have a 2014 LC200 with the same round fog light as yours. Which SS3 vehicle kit did you buy? Diode Dynamics does not have one for the 2014 LC200. Did you buy the Tacoma or Tundra version? Thank you
I did this install, however with a product from AuxBeam for more than half the price. The fit kit from Diode Dynamics is the same fit kit used for the 4Runner and Tundra. As such, I did some looking around for a more economical option. Link is below:
Auxbeam 3" 80W 9600LM LED Pods (ZD000676) w/Flush Mount Brackets & Amber Covers, Spot Flood Combo Offroad Lights Toyota Fog Lights for Tacoma Tundra 4Runner, Bundle https://www.amazon.com/dp/B0B2CD6P3G?tag=ihco-20
I didn’t see any specific answer to the question about the 2009 LX570 Diode Dynamics fog light backlight wiring, which is what brought me here. I decided to pull out the multimeter today and do some testing then wire in my back lights. I searched the internet for which specific wires were the driving light power wires prior to today with no results. Below are the photos of the harness and showing which wires to tap with their supplied wire splicer to run the back lights while driving lights are on during the day.
The first photo is the drivers side. This wire is solid red and on the bottom left corner, when standing at the front of the vehicle looking down at the harness.
The second photo is the passenger side. The wire is red and yellow, also on the bottom left corner when standing in front of the vehicle looking down at the harness.
Third photo is of the driving lights and backlit fogs.
Fourth photo are fogs and low beams on.
Thank you. Pictures are great. How do your headlights look so good? New headlights?
No, I purchased this LX about 4 months ago from a 1 owner that kept it in the garage. The body and paint are perfect and you could have eaten off the interior. It was 1 of 3 vehicle's they owned and rarely drove it. Purchased with 103k miles, just turned 109k today.
Wow! Awesome find.
I just installed a set of amber Diode Dynamics fog lights! Thanks to the amazing people on this forum, it was a snap. They look and work great!
Thanks Again Everyone!
Blessings, Brian
Doing this install and it is kicking my ass on my 2008 LX.
Attempt 1 - got the driver side out fine, got the wiring in, turned on the fog and nothing from the new diode dynamic but still had light from a diode dynamic led in factory housing for passenger side. Attempted to remove passenger side and found 2 seized screws (I guess I know what that cover is for on later models)
Attempt 2 - got the passenger housing out, swapped in the diode dynamics led housing in and now neither light turns on.
1. These are non-backlit model so I am using the non-backlit harness
2. The stock housings with diode dynamic bulbs worked
3. Fuse is not blown
4. Tried turning fogs on with high beams engaged, low beams engaged, parking light/drl’s engaged, no ebrake engaged, in park and out of park, nothing.
5. Dash lights are still indicating that the fog lights are turning on
At this point I am confused, of one side didn’t work I would chalk it up to a dud light or harness, but for both to not work is bizarre. Happy to take any ideas right now.
Try swapping the direction the harnesses are plugged in.
Drew a picture to see if I understand what you mean, like this?
Can’t remember if that plug can be flipped, but unlike incandescent bulbs, LeDs can only be powered one way. So you have to have the + to the + and - to -.
Has anyone bought the SPORT version of these lights? I'd happily take less light output and allow me to use them all the time (not blinding oncoming traffic).
Either that, or a brighter headlight (2013 LX) as our headlights are pretty dim for being HIDs
I have the sport outputs and am happy with them. I daily my truck in a major metro area and don’t get much fog. I run mine in heavy traffic or inclement weather when I want stupid people to see me. The output is still very strong. Unmistakable.
Can anyone comment on the output of the amber backlight in the daylight? I installed the DD elite series fogs and the backlight is not noticeable outside at dusk (pic with amber backlight on below). I’d like to figure out if I messed up the install or if it’s working as expected. TIA.
I just installed the Morimoto 4banger in the fog light location on my 2013 LX. FWIW, after doing the passenger side by removing part of the fender liner, I realized that the liner does not need to move at all. I did not need to touch the fender liner on the driver side. I just raised the suspension to max setting, then accessed everything from the front, just under the bumper. There’s quite a large opening when accessing from center-out. Who knows, maybe I am missing a cover panel.
If this is how your rig sits, you are definitely missing some panels. Those 2 brackets with studs hanging off the aluminum square bumper reinforcement bar are places they attach.
I would guess the backlight isn’t getting power. They are noticeable in the daylight when the amber backlight is on.
How did you power the backlights? Spliced the DRL wire on headlight plug?
