LX 450 security panel function and/or relocation?
tejas
anyone know what the LX450 security panel actually does? is it just an LED showing the FOB was activated?
i didn’t get any fobs and have never used it.
also anyone happen to know if i can get a 97 LX 450 security switch into one of these panels on the left of the steering column?! i pulled it for a CDL switch and right now the damn thing is stuffed behind the kickpanel since i backed out of removing the whole TVSS system.
or can i just leave it where it is?
thoughts? after digging in i am not so sure pulling that TVSS is worth it.
If I'm not mistaken it houses a status LED as well as a "Glass Break Sensor". The only thing I will add to this discussion is that I had the sensor unplugged for awhile, and when the system was armed (locked with the fob), the alarm randomly went off a few times. I'm assuming this was due to the inputs floating as they weren't connected to anything. If you don't care about having the sensor actually work, I'd just leave it plugged in stuffed behind the dash personally.
awesome. thanks. so don’t buy any fobs and just leave the thing behind the kickpanel?
did guys just have problems getting it /unarmed/ after arming it with the fob was that the problem? i never really understood this but thought it was best to pull the whole thing to not be stranded for some reason?
Not 100% people's reasons for not liking the factory system - if it's dealer installed (not sure offhand if that's the case or not) there's probably varying levels of install quality out there. Also, over the year's POs have hacked things up on many trucks, which have caused some people problems from what I've seen on here.
I've never had any problems with mine - I used to use it when I used the fob to lock/unlock, but I got tired of changing the fob battery so frequently a couple of years ago and have just been using the key for awhile now.
alright. this seems bone stock. i thought it was a bad idea to leave it in. that was a long way to go to pull the switch but i guess i will leave it as is.
APPRECIATE IT
here is a pic of the actual switch before it was removed in case anyone wanted to see it. i guess that little sensor on the right is some kind of sound pickup device?
The poor alarm installer that yanked my RS alarm might agree with you. I'm going to reuse that location for my Compustar temperature sensor
You could put the CDL switch in that hole like I did :p
yeah. thanks. that’s what i did.
i was on the TVSS removal thread thinking i would just remove the alarm system while i was in there. but when i got in there i decided to leave the alarm in.
getting that switch over to the left side was a mother though. lots of zip ties buried way back in the dash. make sure to remove the metal panel when you get set up and you’ll save some time. you can also just unclip it at the switch and not hassle with any connectors. you also have to unhook the airbag harness under the steering column fwiw.
next time i might also disconnect the whole panel at the stereo instead of leaving it hanging and having to put the key in and brake on and shifting the shifter back and then pulling the ebrake to get the shifter cover off. i was in there so long i kept having to turn off the key which involves jumping around a lot to the DS and pushing things around every time you have to turn it on or off.
I did my first, without anyone giving me pointers, I now know how to do them, this will probably be you only one, me I am sure there will be more o_O
