Lugging and lunging while full turning
Central Valley Fresno CA
I'm new to the landcruiser club. I'm reading about the birfield joint problems often in my 80 series LC. I have a 94 and when I turn fully or close to full when entering a driveway the vehicle seems to lug and need to be given more throttle. It feels as if something is binding somewhat or restricted in motion. When given more throttle the truck seems to lunge through the turn. Onec the wheel is straighter the problem seems to go away. There is no real clicking noise but sometimes I hear a low rubbing noise even while moving in a straight course. Does anyone have input on this or able any one able to suggest something to help. Thanks in advance.
I'd guess that you have at least one differential lock locked.
If you have a center differential switch, make sure it's off.
If you have a locker switch to the left of your steering wheel be sure that it's turned all the way counter clockwise.
I'd agree with nautilus...
Sounds like the drivetrain is binding up. I'll assume it is the center diff that is locked up or the VC is going out. If it were a front locker turning would be REALLY hard and if it was the rear locker I'd suspect you'd be getting a lot of tire scrubbing noise even shallow turns not to mention maybe some funky handling.
You might try finding a nice dirt field/area and drive around and see how the handling changes...Also try locking in the center diff (via the dash button if you have one or by shifting into low) and unlocking it to see what if anything changes. If the center diff has been locked up for a long time you tcase could be trashed. If it hasn't then figure out why it locked without your knowledge.
Good luck!!
It's a 94 so won't have a center diff lock button unless retrofitted. Maybe somebody locked the center diff in low, pulled and fuse and then kept driving. Check to see if the center diff lock fuse is there and functional.
Check your intake tube between the air filter and throttle body, specifically the accordian section that attaches to the throttle body. Any tears in it will cause lunging and lugging in turns, I think left hand turns exspecially
Thank you for the help
This morning I'm heading out to the dirt. I'm going to engage the front and rear differentials in the low setting. I'll also check the fuse as recomended. I've been reading through other related forums and been getting good information. Thanks to all.
Do your tires skip or chirp when turning, like a parking lot? If so I would almost bet it's the VC mine is seized up(and binds in low speed turns, chirps and skips on the tires) and also caused my front diff ring and pinion to snap a tooth off of each. So be careful!! Full rebuild and regear is soon happening.
My 94 came stock with the Center Diff switch.
Switch on the dash? And this is a US model, new from the dealer?
Yeah, my '94 also came with a stock center diff switch.
Yep... it's on the dash and it's a U.S. model and it came that way from the dealer.
CDL switch ...Only the 91-92 came with the CDL switch installed from factory from what I have read and seen. Harness is still in the dash for other years so it's easy to add.
or front and rear diff switch
How did some 94's have that and my 3/93 truck doesn't, usually a switch over uses up old parts before the new stuff???
Don't know, but the subject has come up here on MUD before. One good reason to post your details in your sig line. It helps the gurus when they're trying to help you out on a problem.
Good point...I think I'll add some detail to my sig just in case.
Wise move, grasshopper:D. No offense to anyone, but I never saw the purpose to showing all the different rigs you own or have sold. IMHO, it serves much better purpose to show your current rig(s) & details/options/mods as they apply to this forum. But, to each their own.:cheers:
