Lug nuts won't budge, help
I've been having no luck getting the lug nuts off the stock alloy wheels on my 96 model. IIRC I tightened them to ~90-95 ft lbs a few months ago, but from searching seems like they shoulda been torqued to 76ft lbs? I could only get two nuts loose after spraying with penetrating oil then wailing on them with a new Ingersoll Rand 14.4V cordless impact wrench. It's rated for 175 ft lb of reverse torque and says it is good for general automotive work, brakes, etc. I also just tried a 20 inch 4 way X type lug nut wrench, only thing I busted was my gut. Can I apply a little heat from a propane torch to the ends of the nuts, or will that mess up the wheels?
If it were mine, I'd try the heat. Also, as you get them loose, tighten them back on to take off the others. The wheel does flex a little, and if you remove 5, the one that's left will have a lot of extra pressure on it.
Anyone know how much reverse torque is normally needed to remove the lug nuts on an 96-97 alloy wheel?
I assume you have it sitting on the ground while trying to break them free? with the vehicle in P and the parking brake set and maybe even the wheels chocked? I'd try to use a socket (are they 22mm? I forget) with a nice long breaker bar before applying heat.
Torque should be 83 ft lb's I believe....should be 21mm socket (also believed :flipoff2:)
so, not a hell of a lot more than that....if torqued correctly.
It might be the alloy of the wheel and steel of the lugnut corroded together.....lube and get a big cheater bar.
Yes, in park, brake set, on the ground etc. Don't have a breaker bar. Using a 21mm deep impact socket (fits).
One good trick I learned from an old mechanic.... Use a socket & Johnson bar, while standing with one foot on the Johnson bar (to apply left rotation torque to the nut) smack the socket end of the bar with a hammer. (like you are trying to hammer the socket onto the nut) This worked on a wheel I couldn't get off, and it's pretty simple and easy. I suppose you could do it with a ratchet, but you might damage it with the hammer...
Sent from my iPhone
I would not do the torch so close to an alloy wheel. At the very least you will likely damage the clear coat.
Impact wrenches are probably better than a big breaker bar, I think the dynamic nature of the hit helps. Use plenty of good penetrating oil overnight, that can't hurt (as long as you don't fling it on the brake parts etc).
If your electric wrench isn't enough, try a big compressed air one. Of course, you want to hang on to the things to help with the impact.
I don't think your torque will have hurt the studs since the 90+ftlbs range is what we use for steel wheels on the same studs. Could have hurt the wheels a bit, though. Are you sure you used the correct type of lugs (as in straight shank vs conical)?
Seriously, try the hammer- you'll be surprised!! Give em a good whack
Sent from my iPhone
A little heat may be in order, but trying a breaker bar first would be a better approach. Don't forget you may have the factory lug wrench by the jack in the rear quarter panel which can accept a pipe sleeve. Unfortunately the shape of the lug nuts makes it difficult for penetrating oil to work into the threads.
I use Never-Seize on the threads when I reassemble, and the FSM states 76 ft/lb.
Thanks for all suggestions. Don't have an air compressor; after I went out and checked prices I would be into it for $400 +/- at least so holding off on that for now.
Thanks for all the suggestions, but my 80 is now dead, no need to remove the wheels. See other thread about impaled oil pan.
I'm confused- you punctured the oil pan yesterday, but posted this thread today, right? Am I missing something?
EDIT- I guess you're saying the truck is out of commission for awhile- but you still will want to get the wheels off eventually, I assume...
Try using PB Blaster. Works great but if that doesn't help an even better penetrating oil is Kroil.
You should be able to get these off with a deep six point metric socket, and a hammer impact tool. You put it into reversing mode and then hit it with a hammer.
I think I could break the lugs loose with a good four way, solid one, not a fold up cheapie. Bad thing about a breaker bar is the side torque wants to pull it off the nut but even this should work.
I had a tire shop break three studs when I first got new tires. They paid for the parts and I put all new studs. 24 studs, all factory parts. Since then, it's been 76 lbs torque. Every single time I go to the tire shop, I have to argue with the guys to do what I ask but this is from the maintenance manual page that C-Dan faxed to me at a tire shop long ago to show the manager. Since then, I have to show them the paper to get this done right.
With your luck, I would buy new studs, maybe new lug nuts as well then go nice and easy and pray that you can get your Karma turned around.
Kernal - where are you located? Perhaps there's someone here close by with a big long breaker bar to give you some extra leverage getting those lug nuts off. BTW - at least on a '94 with conical lugs, FSM torque specs are 76 ft/lbs. AAA member? Maybe they'll come out and get them off. Just another suggestion.
