Lug Nuts for Tundra Wheels
N43.875, W121.455
Website
www.instagram.com
I'm running some spacer/adapters on my CDN M101 to convert to a 5x150 pattern so that I can run the same wheels on the trailer as on the 100.
I had bought some matching LC lugs (tapered base with washers) but pressed in lugs on the adapters are too long and bottom out inside the capped LC lug.
Yes, I could cut them and chase the threads, but the path of least resistance would be to use the nuts that came with the adapter.
My question is would running the lugs in the pic cause you any concern? The wheels are Tundra 18s with 295/70R18 (~34.5") tires on a trailer that all-in may way 1200 lbs. My guess is they'd be fine for this application, they just look a little puny.
