Lucas Oil Additive
Arkansas
Ok.... I know there is allot of info on here, both good and bad, about the Lucas Oil Additive but my mechanic friend believes in it. My 97 LC has over 160K on it now and I have been using about a quart of oil every 2,000 miles. No smoke or anything...it just disappears, and he recommended trying some of the Lucas stuff. So I added a quart with my last oil change and now 2,000 miles later..........I have used no oil at all. My dipstick still reads full and I have noticed no change in performance at all. My engine has always run very smooth but I think it is running even quieter now. Anyway, I'm excited because my oil light is usually coming on about this time and I get to add a quart to get to the next oil change.:clap::clap:
Lucas Oil is awsome! I've been adding it to every oil change and my engine runs quiet and smooth.:D
I agree, I have used Lucas in the past and noticed similar results. I havent ran it for awhile now, but will most likely ad it at the next oil change.
What about Additives?
One reason why I avoid additives.
(It's a little obscure, but the long story short is that Lucas causes the oil to foam, and where air is, oil isn't. So you actually end up with less oil than without the additive).
If it gets chilly where you are, leave a quart of Lucas outside overnight, then try to pour it into another container. If you're happy with the jelly consistency of it sitting in your oilpan waiting to get warm enough to actually get pumped,more power to ya.
Lucas is fantastic for Land ROVERS - it really helps seal *some* of the leaks.
i love lucas. it does get thick when cold, but it's not like you run it straight
Both the 3FE and FZJ motors don't have a problem moving oil if even halfway decently maintained.
There's a lot of reasons not to run an oil additive, and very few reasons to run one.
As far as I'm concerned the only semi-plausible reason to run it would be to use the additives in it which swell the seals to help reduce/stop the oil seepage. The problem is that the seepage will come back, and if you stop using the additives then you're likely going to have the seals in way worse condition than if you'd left it alone.
I remember hearing about a guy who was going to sell his 80 and forked out something like $5 grand to get all the seals replaced where there was seepage. A few weeks later....they were back (granted not as much). These engines tend to seep slightly just about no matter what, but rarely does it become a serious issue if they are maintained. On the other hand, the additives that swell seals have been shown to be likely to cause long term damage.
Everything else Lucas does is actually bad for the engine. It's tougher to move when cold, causes the engine oil to foam so it's more easily moved (air is more easy to move than oil, and it kinda defeats the purpose of the anti-foam agents found in oil), etc.
Lucas is a product that should be used as a last resort type scenario. Not on a PM basis.
