Lt1 - NV4500 Clutch Question
Connecticut
I did a search trying to find the answer to my question with no positive results. I'm doing an engine swap in a 60. I'm using a 94 camaro lt1 and mating it to an NV4500. I'm having a hell of a time trying to find a clutch that will fit my needs. Do I need to change the flywheel? If so what flywheel do I get?
Will this work? http://cgi.ebay.com/ebaymotors/CAT-...egoryZ107063QQihZ001QQitemZ110116244335QQrdZ1
Cheers:beer:
Nick
looks good
That flywheel looks like it'll work .I think you could use any flywheel from an 86 or later smallblock (one piece rear main) so you don't have to spend that much cash. then you could use a standard 10" or 11" chevy clutch. Are you using the internal slave or going with the AA bellhousing?
OK. This is what I'm going with:
LUK Flywheel for GM C2500 Pick Up
LUK OEM Clutch kit to match
If I'm making a mistake somebody stop me!!! I'll be ordering tomorrow.
