LSPV Non ABS delete question
Central Arkansas
'94 with no ABS. From what I can tell I have two options to delete the LSPV. Put a T in at the LSPV for all 3 lines, or put in an elbow in the place of the T where the sensing line returns to the front axle T and then add a union where the supply feeds back axle at the LSPV. The second option would essentially straight pipe the front and rear axles off the MC. Is one preferred over the other, or am I missing something? Anyone who has done an LPSV delete on a Non ABS had better luck one way or the other? It makes sense to straight pipe each axle, but I'm not seeing any problems with just adding the T at the LSPV and taking it out of the system other than more connections and pipe to possibly fail. This rig has drums in the back, and brakes have been spongy since I bought it. Front caliper rebuild kit on the way, backs have been cleaned and adjusted. MC passed the FSM test.
I used the t-fitting as I wanted to keep my abs since its working for now so I pretty much had the one option. without the abs I would maybe delete the sense line and you can add a manual proportioning valve if you want to balance out the brakes
I did read that one and several others, but none I found were specific to Non ABS and my two options. Thanks for sharing link.
I stole this pic from another thread. Makes the options I mentioned a little more clear. I'm leaning toward straight piping directly to the axles, by putting in an elbow (or union) and eliminating the sense line from LSPV to front axle. I just wanted feedback on any problems I'm not seeing.
