LSPV leaking
Houston
Had mushy brakes since I bought it from the second owners and the last time I bled the system I was getting air out of the LSPV. I looked under the truck the other day and noticed that the rubber boot on the bottom was wet and after squeezing it my hand was covered with brake fluid... So I now have a leaking valve in which O-rings might or might not fix, a new one is over $150 I guesstimate. (spent over $150 for replacement brake lines) Seen a few threads about installing an aftermarket proportioning valves either by the MC or in the original location.
So replace it with another of same design, replace it with an aftermarket and hope it's troublefree, or remove it. Any comments on which to go with?
You'll find info on this thread (look also in FAQ) about replacing LSPV with a 'T" joint and be done with it....
