Studded tires will still get you pulled over, then ticketed, then you'll have to be towed as well 80. I wish they wouldn't salt the roads here, but with the snow, melt, then frozen nights, it does make for some trecherous conditions. Besides gravel and salt, they now spray some chemical solution everywhere to try and melt the ice, it probably just feeds the rust.
But back to LSPV adjustment theory. If you give your vehicle a suspension lift, in our case 3", the distance from the frame to the rear axle increases three inches. The valve body is mounted at the frame, and the other end is mounted at the rear axle, so now after the 3" lift, the end mounted to the rear axle is 3" lower than it was before the lift. In order to bring it to back to stock location, you must raise it back up the same amount. In theory, this makes complete sense. I have always wondered in the back of my mind why lowering the LSPV body down only 1/4" at the frame as the FAQ suggests would be enough, but i think it has to do with their angles or something.
I think i have now talked myself out of moving the valve body, and instead will just raise the axle end with my own custom piece of metal. This is how I adjusted my 4runner after its Downey lift, and this was their theory and solution on the matter. It makes sense and it works great on the 4runner, which i beat like a rented donkey. I have to do something though because i can tell the back brakes just aren't there
