LSPV adjustment nightmare
Southern WI
Well, I finally got around to moving my LSPV down the recomended 1/4", and I knew it wasn't going to be as easy as some of you have squaked about. "Oh, it took me five minutes, just loosen the two bolts, slide it down and tighten" Right. Thats like "disconnect the front sway bar" when doing the lift so you can get full droop and fit the new spring in. Only 3 of the 8 bolts broke then, and had to be drilled/retapped in 0 degree weather. Is this some kind of sick joke on me.
One of the LSPV bolts loosened, the other snapped of course, they've been soaking for about a month as well. The valve won't budge, for now anyways. I sprayed it some more after hitting it with a hammer. Is this just a threw bolt, can i tap it out from the front, then get a new one?
If i have to, i'll take my air chisel to it(the LC in general), then come in here and do the same to my computer, so I can never lay eyes on this site again, and all its evil mods and maintenance tips, its sick jokes and twisted lies. My LC, IH8mud, and that damn garage with the oil stained concrete floor are the axis of evil if you ask me.
Damn...that there's some venom. I was about to do the LSPV when I rebuilt my parking brakes but after loosening the two bolts (I know sorry, they broke loose without a problem) I couldn't move the LSPV. So I just tightened the bolt back down and left it. We'll see how the pads last since I replaced them while the rear was apart.
Wow, nice rant. Have a :beer: or many more and relax.
Sorry I don't have a good tech answer for you tho. My truck beats me up sometimes, and sometimes you just have to sit back for a sec.
Dude....you're in the rust belt. What do you expect?
:rolleyes:
Every single bolt on that rig is either going to snap off or is going to be extremely tough to get out.
Ask me how I know.
Oh, and the LSPV, get rid of it and be done with your issues.
-o-
Glad we caught you in a good mood! Anyway, I hear a lot of complaints about attempts to adjust the LSPV. Are you even looking at the FSM? I know the correct procedure would prolly break the average shade tree mechanic in special tools, but for me, it was a relatively simple adjustment, since I ignored all the special tools and just loosened 1 adjustment locking nut and turned the adjustment nut to where I thought it should be. Then, tightened the locking nut and proceded to the testing phase. In my '94 FSM, there's a good picture on page BR-54, bottom drawing, the dimension 'A' is what you are changing. If you are attempting to move a bracket, you are doing the "last resort" adjustment.
Great, I was about to go out there on Sunday to do the same thing on my '92. Incidently, it feels like my LSPV is doing the opposite of what its suppose to if Im understanding it correctly. I have no front brakes post lift.
I've adjusted mine a couple of times and the second time took 1 minute. Rust? What's that? :cool: ;)
What all is Involved in getting rid of the LSPV? is it just a new line from the old input to the rear brakes? I have been tempted to move mine down just to increase my breaking with no lift.
Sorry for the meltdown, I forgot about step number 6:beer:, its all better now, and i will win this battle against the rust. For those of you who live in a rust free zone, you have no idea how hard some of the simplest repairs or adjustments can be on a 17 year old truck. Its worse in the rear half of the vehicle, because thats where most of the road salt is tossed up, and its not bathed in the oil from the leaky engine gaskets.
I have no FSM, but have read the FAQ on this. There are two bolts that hold the LSPV to a braket mounted on the frame. To adjust, you loosen the two bolts and lower the valve. My valve however looked like a ball of rust till i scraped the rust off and could actually see the mounting bolts. While scraping rust away a large chunk of metal fell off, it looked like a tach weld, and on closer inspection it looks like the upper part of the valve is tach welded to the bracket, but its hard to tell with 17 years of salty rust. Is it possible the valve body was tach welded to the mounting frame braket at the factory to prevent movement, has anyone seen this?
I think i can push the snapped off mounting bolt through the valve and bracket, and just replace. It looks like a threw bolt, I imagine it is, but i doubt it will come out, I think it is now one with the valve. I'm hoping i can push this bolt out, free up the valve and lower it, then replace the broken bolt. If none of this works, I have a back up plan thanks to downey.
When i lifted my 4runner, the Downey solution to the LSPV problem was to lift the mounting point of the valves armature at the rear axle the same amount you lifted the vehicle. This makes sense, and may be easier to accomplish then trying to free up the valve body at the bracket. But this wont be easy either, you should see how rusted those two bolt are. If i can break these bolts off without breaking the mounting braket, i may be able to raise the attachment up three inches with a simple bracket and give it a try. Has anyone tried this approach to the LSPV adjustment?
Now I know why you northern guys like to buy our rust free southern trucks.
My adjustment took the five minutes and was well worth it. Work it out and make the adjustment. It does make a difference.
Maybe the '91-'92 is different. I still think you are adjusting the wrong thing. There is a shaft that extends from the valve body (which is frame mounted) to a bracket/shackle assembly on rear axle. It is on this end that you should see an adjustment screw that goes through a shackle with a nut on either side. This is where the adjustment should be made. You don't move the valve body bracket unless you can't get enough adjustment out of the other end. At least that's the way it is on my '94. Hopefully that end has less rust on it! HTH
Here's a picture of the LSPV...maybe you need to post a picture of yours.
Often times there is not enough adjustment to be had by just adjusting the rod on the axle housing. The FSM calls for the adjustment to be made on the LSPV itself, at least for my '97.
Tenzig does have a point though, unless you've had a truck from the rust belt, or currently live and deal with on an annual basis of continually rusting parts, you really have no idea how frustrating working on the undercarriage can be. It's not just a matter of PB blasting every nut for a week or two. There's really nothing left on many of the bolts to put a wrench on. You almost have to figure in time-wise when you're doing maintenance that you're going to break a bolt, or strip a nut that has the consistency of drain sludge.
And don't take offense Homers, but posting a picture of your rust-free LSPV really isn't making him feel any better about the job he's trying to accomplish. We can look in our manuals or a parts microfiche to see what any part looks like new, which is often times different than what it looks like after 10 midwest winters.
Now to answer Tenzig's question... I couldn't free up my LSPV at the frame side because the nuts, bolts, and LSPV itself oxidized into one big blob of rusty crap, and I also couldn't move either nut on the axle side as well. I cut off the axle side threaded rod and welded a new piece of threaded rod that was approximately 3-4 inches longer than stock, and then put on the adjuster with two shiny new nuts. This allowed me to adjust the LSPV the approximately 3 additional inches higher than it was pre-lift. There was also a solution that landtank devised to use a sleeve and threaded rod to extend the stock threaded rod on the axle side. You can search on "landtank" and "lspv mod" to find it.
Good luck, and I feel your pain Tenzig. :)
Great pic of LSPV! It's mounted to the frame. But according to the '94 FSM the adjustment for the LSPV STARTS at the other end of the shaft or what the FSM calls the "Load Sensing Spring Assembly" (LSSA).
In my pics which shows the other end connected to the rear axle housing, there's a vertical threaded shaft that the LSSA attaches to. There's 2 nuts, 1 below and 1 above LSSA that tighten and hold the LSPV adjustment in place. Loosen top nut and with bottom nut you can move that end of LSSA up or down on threaded shaft. In a suspension lift you have effectively increased distance between axle and frame, you need to come up the shaft with the adjustment to regain the stock adjustment. The '94 FSM says that if you can't get enough adjustment at this end, then move valve body. I had success at the axle end. Hope this helps!
Thanks all for the great suggestions. We have pretty much covered every possible way this problem can be solved. Now hopefully I can make it happen without breaking to many things.
I looked at the adjustment nut before starting, the one 80 is talking about, and can only raise it 1/2", not enough to make a difference. Extending this threaded rod by welding on a new one, or extending the present rod with a sleeve looks like an easy option as well. Since I've already broke one of the valve body mounting nuts(like in Homers picture), I think I'll still stick with this method of adjustment. I'll just use a bigger hammer and drift on the bottom of the valve body to see if i can free it up, then hang on it to bring it down into place, I even put the sharpie mark on it already.
And those pictures of rust free undersides, don't they make you envious chitown? I laugh when I see them, but when i'm under the truck I curse, I hate, and I cry. A five minute bolt for some is an 8 hour tour for us. And sorry for the lack of pictures, I can't afford the camera now because I spent all my money on titanium drill bits drilling out broken bolts.:bang:
Tenzig, I feel your pain as well!
BOTH of my bolts broke off! I took a hammer to the valve, but it wouldn't budge - I just left it there, rusted into place and drove the truck to see how it worked as is.... the answer, not too good, my ft brakes were worn out within 8000 milea and my rear brakes are only slightly worn.
I plan on going back and using Landtanks idea.
Tenzig,
Please understand, I'm trying not to beat a dead horse here, just help. I'll try not to make a book out of this, but, here goes. You've got the same lift in the rear that I do, right? That being said, I have to ask myself why do you think that you need more adjustment than is provided by stock parts? (I didn't.) Prolly from what others have said. Don't know the Landtank story, but I also don't think that you need 3" of adjustment for a 3" lift. Take a close look at my pics and the distance from the end of the threaded shaft that mine is set. I still have more adjustment (for a higher lift). Worse case, you could always form (I'm a technician and techs NEVER say bend;)) that link to make it work. I may have "formed" mine, I can't remember.
On a side note about the "rust belt": It's each State's choice what they use on the roads in the winter. I was stationed at Grand Forks AFB, ND back in the 70s and my wife (ex-wife now) was from Green Bay. We spent many a mile on MN & WI roads. Are they still as rabid about tire studs as they were back then? I remember if they caught you in WI with studs on they would impound your car and fine you just for starters! I've lived in a few places that don't salt and traveled enough to see the differences at state borders on road conditions. There's pluses & minuses for both, but there's no arguing what salt does to an automobile!
Sure, it used to make me envious. But the rusty bottoms have now grown on me and I don't know any other type of vehicle. :)
I think it just teaches us rust-belt'ers patience and perseverence when working on our trucks. :D
Growing up in Ohio taught me the value of products like PB Blaster et al. But in the end the bolt head or nut becomes mush and you invest in a set of taps and dies. Good luck to you!
