LSPV adjustment = improvements
landcruising
Mud User - Not Abuser
San Diego
I finally got around to adjusting the LSPV after an ome 850, 860 lift, tires etc and have a few question. I did notice a bit more front end dive after the lift during braking so I lowered the LSPV by .25" as described in another threads (5 min job). Now I appear to have greatly improved the braking and it seems better than when i got it in stock configuration 6 month ago. It also seems to drive much smoother without braking but this is hard to explain.
I do need to replace the rotors and pads but now most of shimmy or lurching during stoping has been greatly reduced. I originally thought this was a result of warped original rotors with 110K miles.
My questions are,
Does adjusting the LPSV have any effect on the brake system during normal driving without braking (any constant pressure or variation on the system from front to back) or is it simply just adjusting the pressure between front as rear during braking as I originally assumed?
And could the original setting of the LSPV been off that much prior to purchasing that a simple adjustment resulted in a great improvment by distributing the front to back proportioning better?
Yes
Yes.
-B-
Best way to solve the LSPV issue is to remove it, DRASTICALLY improved my braking, and I had adjusted mine after the lift and seen a great improvement there too. But removing it was night and day. And hell, what's a set of $40-70 pads compared to better braking.
And before I hear about worry of the rear end coming around and what not, someone please show me some real evidence of this on a cruiser. Beno has rear discs without the LSPV, says it is an improvement, and isn't worried about the rear end coming around on him. I have drums and tried to get the rear end to come around, even with a larger MC I couldn't get things to go out of control (no ABS either).
Beno doesn't worry much about anything concerning his truck. :D
attachment.php
-B-
:lol:
And Dan told me that everything Onur removes from his truck is an "improvement."
:flipoff2:
-B-
Hope that wasn't a result of removing the LSPV. Either way it appears that many have better braking by adjusting or removing it. Thanks.
Beno removed the complete ABS system and the LSPV. The LSPV feeds back to the ABS system. Use caution if you are removing only the LSPV. You may want to read some of Landtank's posts when he was having his braking problem and he was doing diagnostics involving the LSPV and the interaction with the ABS system.
After thinking about it, I believe Beno replaced the factory "load sensing" proportioning valve with a "manually adjusted" proportioning valve. That was his plan but I am not sure if he has everything in place. He picked up a unit from Summit Racing or somewhere like that.
-B-
Maybe it's the rear drums, but my fronts lock up much easier on low traction (down hill wet red clay mud) than my rears. And I don't recommend this for an ABS vehicle...as I don't know its function with that system (although I wouldn't question it if I had my own ABS rig).
But even with my LSPV maxed out with a 2" extension on the axle and brand new performance shoes, I never could get too much rear brake. Even with the bigger master cylinder I don't have issue.
Yer prolly right that the different systems do make a major difference and if you have taken the time to test the braking (and a down hill wet red clay mud area is PERFECT for that), then I think you verified that you are getting better braking performance without risking a rear end slideout. I definitely wouldn't do it with 4W disks though. Anyways, good on ya! :cheers:
-B-
that's were i got mine... :cool:
Rolled once on a snow-packed hiway and he was forced into it. Has spent a bunch of time and under the hood replacing every conceivable rusty part and is fanatical about maintainence. I will grant you that he is MUCH weaker in the appearance department. I have a replacement body for him when he is ready.
Uh Dan....
Can I grab those front control arms first before the body?
I really want my truck to track straight for once!
:lol:
-o-
PS Beo: You love that picture don't you. Luckily, I have a picture of a Saran wrapped 80 series. But I have no idea who's it is.
:p
It is the default desktop wallpaper for every single computer in our company. We changed it to a soothing landscape picture of a lush green meadow in the mountains with a blue lake about 6 months ago and there was an uproar... everyone wanted the Mad Max SUV back.
Do you have a hi-res version? :flipoff2:
-B-
-B-
:lol:
PS Tech content apropros to this thread:
1. I did get rid of the ABS unit.
2. I did get rid of the LSPV at the frame rail in the rear. I put a 3-way there instead.
3. I do have the same manual valve pictured above (it has metric fittings..I got mine from Kirk who got it from Summit).
4. I have not installed the valve yet. Another summer project.
5. I am careful how I drive. I drive as someone would with no ABS system. Slow and methodical and very alert of my surroundings in the city especially.
holy old post retrieval batman.
Anyways, beno, do you have a the prop valve in there now or just a 3 way. Im removing the abs this evening, and was wondering if you had put in the prop valve or if its still out 2 years later.
Thanks in advance.
Will,
Let me know how that goes. I was planning on doing it, but not enough time before the ACT '10 to get it done...I'll get it done after we get back, so try and remember what you do! :D
Todd,
As i write this the abs unit is sittin on the floor, the new non abs master is about to go on and the lpsv will soon be layin in the s*** pile as well. Im puttin in an aftermarket prop valve. Ill let you know how it works out.
